Old 08-22-2014, 09:29 AM   #1
Mr.Hyde
center console
wondering what you guys have made for center consoles i am currently designing one so i can avoid cutting up doors or putting in kicker panel speakers and was thinking of putting them in a center console with a modern stereo so i can keep the original look of the dash without gashing a big hole in it for a cd deck.
ill share my design.
Also wondering if speakers in that location will work?
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Mr.Hyde is offline   Reply With Quote
Old 08-22-2014, 11:23 AM   #2
bigmac73
bigmac73's Avatar
Re: center console
here is what i had built by a local wood hobby shop for mine
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 08-22-2014, 11:24 AM   #3
bigmac73
bigmac73's Avatar
Re: center console
I think your idea looks better for Bucket seats, but i still have a bench seat
Mike
Old 08-22-2014, 04:07 PM   #4
Mr.Hyde
Re: center console
Mine is for a bench I plan on having the high side under the dash
Old 08-22-2014, 04:28 PM   #5
Mr.Hyde
Re: center console
I maybe a not over Ambitious with my idea I have yet to go actually take measurements the speakers being so close, is that an issues do they have to be decided in any way? I plan on just having 4" or 5" speakers in there
Old 08-22-2014, 05:26 PM   #6
Andy4639
Old member
Andy4639's Avatar
Talking Re: center console
If done right a aftermarket radio looks just fine in the dash. Now if you want a Nav screen then by all means build a console for it! As long as there is enough air space in the console they will be fine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-22-2014, 06:59 PM   #7
Mr.Hyde
Re: center console
I wanted a switch panel above it I want to install a few different things... Such as lights in the grille, kill switch and whatever crazy things I think of.
Old 08-22-2014, 09:27 PM   #8
oldschool18
oldschool18's Avatar
Re: center console
there is plenty of room for speakers even 6x9's and if your not sure just don't seal them in or cut a hole or leave an opening for air to move inside console. I didn't put speakers in mine but I did add a subwoofer.
Name:  center console 3.jpg
Name:  center console 4.jpg
_________________________________
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
Members Met......2003Silverado (Dave)
oldschool18 is offline   Reply With Quote
Old 08-22-2014, 11:32 PM   #9
Mr.Hyde
Re: center console
That looks like a might fine design. How would having a port in the console change the sound and quality of sound?
Old 08-22-2014, 11:58 PM   #10
oldman3
oldman3's Avatar
Re: center console
Here's mine, I also have a bench seat. I have AC controls, radio and power window buttons in mine...Jim
oldman3 is offline   Reply With Quote
Old 08-23-2014, 12:00 AM   #11
oldschool18
Re: center console
if the area is sealed and is to small for say a pair of 6x9's it might give you a lot of bass, not a lot like a sub but it might sound distorted a little. But that shouldn't be an issue like I said there is plenty of room, you would have to build a tiny console which it doesn't look that way. you can always build it and if they sound dull or don't seem like they are very loud just take a side off or drill out a large hole and try again.
62 Impala
70 C-10 LWB
71 K-10 SWB
85 C-10 LWB==SOLD
01 2500 HD
