Old 08-09-2003, 12:29 PM   #1
landon4421
Life is Good !
landon4421's Avatar
4X4 rebuild help !
please go here -----> http://67-72chevytrucks.com/vboard/s...threadid=64044
'72 Chevy C10 4x4 shortbed "Project"
'71 Chevy C10 2wd longbed "partsrunner"
'91 Chevy Burb 4x4 "kidrunner"
'14 Honda Accord Sport "commuter"
landon4421 is offline   Reply With Quote
Old 08-10-2003, 07:05 PM   #2
ljbear
ljbear's Avatar
Landon,
I posted a reply and picture of my springs at the other thread.
LJ
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 08-10-2003, 08:35 PM   #3
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I seen the pics, looks like the springs are too long.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-15-2003, 01:24 AM   #4
Scrub
Collector of rusty Items
Scrub's Avatar
I am doing exactly the same as you. A 1972 with 60 and 14, and my springs look exactly like yours when there is no weight, that is the shorter set that yo put on is just like mine. They will settle in fine when you drop the axle in and set it down.
Good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
