welding rearend axle seats
And pinion angle.... should i install the bed or does it really matter?
Re: welding rearend axle seats
Yes!
Install everything first and set the pinion angle with the suspension loaded and then weld the axle perches in to place. |
Newbee
x2
Okay thanks, ive read and asked a few people online...but a friend of mine was telling me doing so was unnecessary....it didnt seem right and before i did so just wanted some more clarification.
Thanks guys! |
Read this before welding. I got it from this site.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf This one is pretty good too-also from this site. https://www.youtube.com/watch?v=T4P75ZQvpws
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 Last edited by jjzepplin; 08-23-2014 at 04:45 PM. |
Tools I used was a tape measure, two rafter squares and a degree finder. I used the rafter squares on the outside of the perches to get a true measurement to clear the center of the differential. All went smooth and was a great fit. IIRC one of the perches was about 1/8" off but that is fine in my book, I am not too picky :-). Good luck.
![]() Join Date: Jan 2012
I've always heard you set the ride height ( by jack stands or springs) and set your 3 degrees pinion angle and weld on! does any one make brackets for a 14 bolt coil spring setup??? I can weld just to lasy to make my own brackets!
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS ![]() |
Thanks guys!
