Old 08-22-2014, 05:25 PM   #1
MurphyGirl
1972 Chevy C20 Fuel Gauge--Help!!
Hey all,
Needing some help here. Our 72 Chevy's fuel gauge only reads full. Guy we bought it from said it was working but quit. I need some troubleshooting tips on how to repair this, or should I just take it to a professional? Just had to run gas to my 16 year old who drives it because he ran out. I am a nice mom, but not nice enough to do this often. Just want it fixed. Any tips would be greatly appreciated!
Murphy Girl
MurphyGirl is offline   Reply With Quote
Old 08-22-2014, 06:52 PM   #2
crazychevyc10
Re: 1972 Chevy C20 Fuel Gauge--Help!!
It might be the fuel pump floater. Mine stop working too. maybe others can chime in on this too
crazychevyc10 is offline   Reply With Quote
Old 08-22-2014, 07:19 PM   #3
1972BlueC20
1972BlueC20's Avatar
With the key in the run position, pull the tan wire that runs to the sending unit on the fuel tank behind the seat off. If the gas gauge doesn't move at all with that wire pulled off then you need to most likely replace the fuel gauge. I just went through this with my 72. I ended up changing the gauge and got a new wire that runs from the sending unit to the fuse panel. I also replaced the sending unit first, because I was told it may be the sending unit or float. It ended up being the gauge itself. It works perfect now. Also check your ground that runs to the gauge cluster.
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559
1972BlueC20 is offline   Reply With Quote
Old 08-22-2014, 07:45 PM   #4
undertaker72
undertaker72's Avatar
I second on checking your ground
undertaker72 is offline   Reply With Quote
Old 08-22-2014, 11:35 PM   #5
Roadster_g
I had replaced my sending unit and guage still wouldn't work. I foolishly didn't check with an ohm meter first.
My problem ended up being a $10 resistor that sits behind the fuel guage. Now works fine.
greg
1972 GMC 4X4
Roadster_g is offline   Reply With Quote
Old 08-23-2014, 02:02 AM   #6
70LonghornCST
Moderator
70LonghornCST's Avatar
If the gauge reads full, there are three possible checks for you:
1. a cracked/cut wire is grounding out along the way from the fuel tank sending unit to the fuse box.
As stated before, it's the brown wire.
2. the flat resistor behind the gauge is out and needs replacing.
3. the float is stuck in the up position. (I'd check this last as it's the least likely possibility).
Keep us posted.
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
