08-22-2014, 11:46 PM | #1 |
pinion angle question
Hi i have a question about pinion angle on a 1968 chev truck
i am installing a 5 inch lowered spring and 1 inch lowering blocks wanting to know will i need pinion angle shims for this set-up thank you everybody |
08-23-2014, 12:00 AM | #2 |
Re: pinion angle question
The general rule is to have the pinion angle equal AND opposite of the transmission tail shaft angle at ride height. You can get an angle finder fairly cheap and figure out which shims you need after you do the math. Good luck!
Jeff
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
08-23-2014, 12:03 AM | #3 |
Read this.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf |
