Old 08-23-2014, 01:01 PM   #1
JakeDW
JakeDW's Avatar
Thickness of box and round frame tube.
I am on the last stretch of building my truck after I get it on the road and enjoy it for a bit I want to build a complete chassis for it while its in use.
I have always used 3/16 square/rectangle tube or 1 1/4 round tube.
I want to be able to bend the round tube.
So my question to build a complete frame how thick of material should be used.
I want the main chassis to be rectangular tube and k member ect to be round.
Thanks Jake
JakeDW is offline   Reply With Quote
Old 08-23-2014, 05:35 PM   #2
tinydb84
tinydb84's Avatar
Re: Thickness of box and round frame tube.
I am no expert but I have seen many builds on here and other site where they run .120 wall with rectangle tube. If you look at back half kits they are usually the same thickness.
They height of the frame plays a big factor though.
David
Instagram: myfabguy
Old 08-23-2014, 05:42 PM   #3
JakeDW
JakeDW's Avatar
The truck will have air ride front back.
Jake
Old 08-24-2014, 01:57 PM   #4
SCOTI
SCOTI's Avatar
Frame rail height.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-24-2014, 05:24 PM   #5
JakeDW
JakeDW's Avatar
Originally Posted by SCOTI View Post
Frame rail height.
Thinking 2x4 for the main rails
Jake
Old 08-25-2014, 06:37 AM   #6
PGSigns
PGSigns's Avatar
If not running a cage in the truck 2X6 would be better. Will be closer to the stiffness of a stock frame and will have a lot less flex than the 2X4.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-28-2014, 05:51 PM   #7
JakeDW
JakeDW's Avatar
Jimmy
That seams really tall it would not be stiff enough with front cross and k member and at least 3 other crossmembers in the bed area?
thanks jake
Old 08-28-2014, 07:28 PM   #8
tinydb84
tinydb84's Avatar
If you are running 1/8 wall 6 would be good. If you were doing 3/16 I would do 4.
David
Instagram: myfabguy
Old 08-31-2014, 04:48 PM   #9
Snailed
Snailed's Avatar
Ladder frames have terrible torsional strength because they have no height and little connecting the two sides. Most of the stuff offered out there for custom frames is .120 wall 2x4 and it's pretty flexy but has OK beam strength. I would do .120 2 x 6 mostly so you can make your cross members taller and try to get some torsional strength. If you are not trying to make stiff suspension work correctly then maybe it doesn't matter to you. Some air springs end up with a pretty low rate so torsional strength may not matter as much.
I would be curious how many pounds/degree a stock 60's truck frame would come in at in a torsion test. I bet it's about 900lbs/degree. A modern sedan is around ten times that and they handle as such.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
