Old 08-23-2014, 04:05 PM   #1
parrisc19844x4_468
parrisc19844x4_468's Avatar
need help with power door locks
trying to get the power door locks to work in my 83 silverado. I dont have any power at the doors so trying to figure out where its going wrong. First went back to the relay, and didnt find any power there so I am trying to figure out which orange wire supplies power to the relay? any ideas? I have taken a picture of my fuse block and relay.
which wire supplies the power to the relay?
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 08-24-2014, 01:01 PM   #2
parrisc19844x4_468
Re: need help with power door locks
ok, I know have power on that orange wire, need help now to find the source of power to the relay, 2nd picture? Anyone
Old 08-24-2014, 09:30 PM   #3
gmachinz
The orange lead to the relay IS hot at all times-the black wires are chassis grounds, with the gray and blue leads going to each respective power lock switch. The relay has dual contacts where a negative pulse is triggered every time you hit the lock switch-this is why any lock switch will lock all doors. You may have a bad relay or the switch contacts are goofy...does either switch lock the doors?
gmachinz is offline   Reply With Quote
Old 08-27-2014, 10:54 AM   #4
parrisc19844x4_468
Thans for the response GM.
As it turned out, I blew the fat 30amp fuse just above the orange/blk wire. I had laid out all my door locks and wire harness and the relay. i did the unthinkable, I didnt disconnect the battery and blew my new $5.00 fuse. I put the new fuse in and bingo.. just the driver side lock works. that sucks. Back to the drawing board. in My 83 (parts are from a 86) sliverrado there is only one switch that controls both doors. Is that normaly? My guess is yes as the door panel only has the opening for a one switch configuration. I know the door actuator works as it worked when I had it all laid out. I apprently have the wires wrong somewhere.
Old 08-27-2014, 11:01 AM   #5
gmachinz
There shouldbbe a single switch on the passenger side as well. The blue and grey wires from each switch run parallel to the door lock relay. My guess is somewhere in your loom one of those wires are grounding out.
Old 08-27-2014, 12:36 PM   #6
parrisc19844x4_468
right forgot to say that, there is a single switch in each door.
ok, i will trace down the blue and grey wires,
Old 08-27-2014, 08:16 PM   #7
gmachinz
You should have a 2-button switch on drivers, single button on passenger side. If you think you may need new LH and RH door harnesses, let me know-I have them on hand....might make it easier for ya.
