Relays for headlights
This has been discussed more than once before, and I was always of the opinion that a relay wasn't needed when running halogen head lights. I've run halogens in every vehicle that I have owned for as long as I can remember with no problems, that is until now. I have a new headlight switch from Danchuk, and halogen sealed beams in my TF. Last night I was coming home from a cruise in about 25 miles from home with the dim lights on. It was fine on dims but when I switched to brights it only took a minute for the lights to start going on and off. I turned the lights off for a few seconds to let the bi-metal strip on the switch cool down, and then turned them back on on dim and drove home with no more problems. I'm only throwing this out because I think I have commented before that I didn't think a relay was necessary, but apparently the switch in a TF isn't capable of powering Halogens reliably. It could be just my switch but it is new.
Re: Relays for headlights
I added headlight relays (and others too for other high load stuff) when I rewired mine. I had a couple of close calls with the stock wiring and wanted the peace of mind. Plus I plan on upgrading to more modern lamps in the future.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
I installed a relay harness and Hella Vision Plus H4 conversion a couple days ago. Havent got a chance to try it out yet since my truck is halfway through the CPP Big Slam kit install.
Installing relays is simple and inexpensive and keeps your switch (s) from overloading or burning out.
On my 71 GMC I was going through dimmer switches about every three or four months with 55/100 H-4 bulbs. After putting a pair of relays in no more problems. I put an inline fuse in the power feed to the relays. Around here you need all the light you can get at 03:45 in the morning on the way work as there are quite often drunks staggering up the side of the road and sometimes in the road usually wearing all dark clothing.
Can anyone post a schematic on how to wire in relays? Also are two required for low and another two for high beams? Many of us can rebuild a tranny or a carb blindfolded but are lost when it comes to wiring.
58 Apache short fleetside ona 64 chassis: ![]() |
Will when I get to my computer..
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
I had the same problem on our 84 with headlight flashing on and off.
I found a kit that had a sub harness and relays that plugged in to the existing connections. I got it from LMC. It was cheap and took me about 10 minutes to do. If they don;t have one for our old trucks, I would buy the one for an 84. It wasn't much more than sourcing the components myself.
Wayne 1) My new 59 blue fleetside truck 2) Making a new box cover fit an old truck - The tonneau cover thread. 3) Raising the 84 back up out of the weeds |
Here is the diagram I used but with the following modifications:
The low beam wire from the dimmer switch is light green, not tan as shown. The high beam wire from the dimmer switch is tan,not green. You are inserting the relays in to those wires before they go to the connectors to the lights at the fender wells. I ran two 12 ga. red wires from a power block I mounted next to the battery, not one. Thought was that if I had a problem in that part of the circuit I would only loose high or low, not all lights. I used a 16 ga. fusible link wire from the power block to the red wire. You can use a fuse or circuit breaker fuse BUT need to make sure that you find and fix the problem that caused the fuse to blow or breaker to trip. I mounted mine on the driver side of the radiator brace close to where the factory connector to the driver lights is located.
I already had the relay when I rewired my truck using an EZWire kit. I've just never needed a relay with halogens before so I elected to skip the few extra steps and leave it out. To keep it simple but still functional I will stick with only one relay that will be in the feed to the dimmer switch. The wire from the light switch that formerly fed the headlights will only be used to pick the relay. I have new wiring so I don't think I will have any noticeable voltage drop to the headlights with this configuration. The feed to the dimmer switch will connect to a full voltage point and will definitely be fused.
That will work too, keeps the big load off the switch. I think the EZ wire size from the dimmer switch is larger than the stock 20 ga. too, but would have to look to comfirm, to allow for newer higher amp draw lights.
ezwire has an auto reset breaker in place of the headlight fuse, but chances are that is not your problem
the bimetal switch is what is causing the headlights to flash reach up under the dash with a pair of needle nose pliers and bend a little more contact in the bimetal strip you will still be protected by the breaker in the ezwire harness and that is protection for the headlight circuit you could also solder the points closed as your still protected with the breaker no relays needed ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#13 | |
#14 | |
Orrie, Looks like I need to install the relays. Had my high beams on last night for the first time and after a couple minutes that flashed rapidly and then it killed all the headlights. I knew right away that it was that bi-metal breaker in the switch, so I let it cool off a minute and made it home on the low beams. Going to use your diagram to wire the relays in. Is there any mod I have to do to the headlight switch?
"Built- not bought" 1958 GMC 150 4x4 in progress 1980 K20- Restored 1985 K3500 Flatbed 58 GMC 4x4 build thread: http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675 |
#15 | |
Orrie, Looks like I need to install the relays. Had my high beams on last night for the first time and after a couple minutes they flashed rapidly and then killed all the headlights. I knew right away that it was that bi-metal breaker in the switch, so I let it cool off a minute and made it home on the low beams. I'm going to use your schematic to wire the relays in. Is there any mod I have to do to the headlight switch?
#16 |
No, switch stays the same with the wire to the High/Low switch now becomes the exciter wire for the relays. (terminal 86).
#17 |
Here is what I have on my square truck.
My neighbor has them on flebay (sunset fabrication), they only require a new 12ga feed from a battery source and a ground
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#18 |
I wired mine as I mentioned before, using only one relay. I haven't measured the voltage at the headlights to see if there is a noticeable drop but the lights seem bright to me and don't go off so I'm happy. I have all new wiring so I wouldn't expect to see much voltage drop at the lights. You can always take it a step farther by using multiple relays but the single relay like I did would probably be sufficient for most of us.
#19 |
Thanks. I'll get a couple relays and wire 'em in. So did you tap into the wires on the harness on the driver's side inner fender or on the firewall? I used a new, stock style harness in my rig that i modded.
#20 | |
I actually pulled the relays along with their bracket off a late 80's Jeep Cherokee in a friend's wrecking yard for a couple of bucks. This isn't pretty but it was cheap and available when I didn't have a lot of pocket change. ![]()
#21 |
I called Autozone to see what they had for headlight relays and they were clueless as usual. Got a source? Looking for new ones.
#22 |
I mounted mine on the radiator support up high, see picture. Third relay bracket is for future driving/fog light relay. The relays are Bosch type from Pico I got from a local auto electrical supply and repair shop.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 07-05-2015 at 11:55 PM. |
#23 |
Thanks for the pic, Orrie. yup, I like where you mounted them. I don't like mounting things on the inner fenders. I will check at that auto electric shop over on Overland and Vista.
#24 |
Yes it is Huskey Auto Electric, located a couple of blocks east of Vista. That is where I got all my special switches, etc. They only sell quality stuff. Also can rebuild starters, generators, etc. or supply rebuild parts for them. It is only about half a mile from my house.
#25 |
My last comment on this: If you want to use the one relay method you can do it all right at the light switch. I mounted my relay to the top of the kick panel. It's the easiest way to do it and there are no extra wires needed other than the wires from the switch to the relay, and it isn't visible under the hood.
