![]() Join Date: Apr 2011
66 3/4 ton front suspension
Curious what the difference is in the 3/4 ton front suspension and the 1/2 ton
Just the springs? and of couse the 8lug hubs Are the upper and lower arms the same? |
![]() Join Date: Sep 2006
Re: 66 3/4 ton front suspension
Lower control arms bolt up differnt'y then the 1/2 ton stuff.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
Curious if I roll the complete front end out from under a 3/4 ton longbed will it bolt to
the 1/2 shortbed chassis? I know that is a very random question but just hate to waste a brand new set of 8 lug wheels with tires and disc brakes Anybody ever built or seen a short bed fleetside with 3/4 ton suspension?? |
Most go the other way, but there's no reason you can't put 3/4 ton stuff under a 1/2 ton; a search will bring up quite a few hits from guys putting C10 stuff under a C20.
thanks
just hate to waste these wheels and disc brakes |
If you want a softer ride put the 1/2 ton springs in the front or get the lightest 3/4s you can find and if your using the leafs in the rear break them down and remove a few leafs like every other one or every third one
