View Poll Results: Black or Grey primer?
Black Primer.. 18 56.25%
Grey Primer.. 14 43.75%
Voters: 32. You may not vote on this poll
Old 08-09-2003, 02:27 PM   #1
boataddict26
Question Black or Grey primer?
I am going to start sanding my truck within the next couple of days and cant decide which color of primer to go with. Keep in mind I am going to have to drive around with it in primer for awhile untill I get up the money for paint.
1978 Chevy C10 Currently under resto.
350 Getting face lift. .060, JEpistons, Modify heads. More will come with money.
boataddict26 is offline   Reply With Quote
Old 08-09-2003, 02:44 PM   #2
lofat
Rollin' Member
lofat's Avatar
voted
:: 1977 C10 cheyenne ::
:: 1973 new yorker brougham :: for sale - $1,500
lofat productions
lofat is offline   Reply With Quote
Old 08-09-2003, 03:13 PM   #3
Kenneth
some thoughts on primers:
I've been warned about driving cars around with just a primer coat. Primer is designed to create a nice adhesive surface for the paint and it doesn't seal the metal from the outdoor elements. So you can still get a nice bit of rust with your primer on there. Just make sure your time between primer and paint isn't year. Also you could just use some Crylon spray paint over the primer to ensure good protection before your paint job.
I'm partial to grey primer.
Kenneth is offline   Reply With Quote
Old 08-09-2003, 04:46 PM   #4
boataddict26
Thanks for the advice Kenneth. I thought the primer would seal out the elements. If I primer, and rattle-can I should be ok?
Michael
Old 08-09-2003, 05:43 PM   #5
Kenneth
I'm no professional, but last year I called a body shop about getting an el camino sanded down and primed (I don't have a garage to do the job), and I told them I wanted to hold off on the paint, so they suggested I do the rattle can thing for the reason I mentioned.
We might need some more imput on this one. But I'd say you'd be alright after the rattle can and if you use black and army green you can get a nice camoflage effect.
Old 08-10-2003, 04:33 PM   #6
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up
A few other thing's to consider is the final color coat if you are gonna go with a light color go with a light primer or grey if your gonna go with a dark color go with the black primer.
Also being in florida black isn't a good choice as you may know.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 08-10-2003, 07:35 PM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I like gray.
The primer you use is important. Use some really good stuff and you won't have to sand back down to metal to repaint. The bodyshop used some Dupont on mine. The stuff is so good a local 55-57 restorer would not touch it until I have him the name and product used. The primer is good so only the minor scratches and road damage need to sanded back down before painting.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 08-10-2003, 08:27 PM   #8
Hard_Core_Hick
Personally i would go with Tremclade Flat black and if you look at it this way it wont rust
I need a 454 4 barrel and dad wont let me get one
Hard_Core_Hick is offline   Reply With Quote
Old 08-12-2003, 12:01 AM   #9
tazman
as said before it depends on what color you are going for after- here we go-- if you are going for a dark color and want depth use black-- if you are useing a dark color and want a touch lighter as in blue with a gold under tone use grey--- if you are going for a lite color use grey and of course the exception to the rule if you are going for red then red primer. one thing you have to remember is if you rattle can it, to get a real good shot when you do the real paint-- the rattle can paint will have to go--which means more prep work on final paint there is a primer sealer on the market but it only comes in a med grey but it does work on it's own with out to much affecting it as in dirt, grease and other afflictions of normal life
tazman member of Mojave Street Rods
tazman is offline   Reply With Quote
Old 08-12-2003, 12:33 AM   #10
CT-Truckster
CT-Truckster's Avatar
i say gray, the black gets really nasty looking after just a short while, plus the gray will be a little cooler.
CT-Truckster is offline   Reply With Quote
Old 08-13-2003, 03:21 PM   #11
bigd65
bigd65's Avatar
use the oposite of the color skeem, that way when you paint it you can tell thin spots
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 08-13-2003, 03:21 PM   #12
boataddict26
Thumbs up
Thanks for all the advice. I am painting the truck silver wich is a lite color so I am going to go with the grey primer. I wont use rattle can either. I was planing on it but the extra prep work didnt dawn on me until tazman mentiond it. What is a good primer to use and where can I get it?
Thanks Again,
Michael
Old 08-13-2003, 03:24 PM   #13
boataddict26
BigD65 just brought up another good point!! It seems like it would be MUCH easier to paint silver if the primer was black. You could easily tell where you have already painted. Any comments on this?
Old 08-13-2003, 06:42 PM   #14
Desert Rat
Desert Rat's Avatar
Id use black.If you use a epoxy primer/sealer then you dont have to worry about the weather/moisture being absorbed.I personally wouldnt rattle can it.Typically looks like crap.go for black Unless you live in AZ like i do!
Desert Rat is offline   Reply With Quote
Old 08-13-2003, 07:53 PM   #15
boataddict26
I live in Florida. It gets pretty hot here too. If heat is what you are talking about.
Old 08-13-2003, 11:40 PM   #16
Grey 87
Grey would be the primer to use if your going with silver, but if you are doing your own body work its easier to see if your work is straight if you use black.
87 SWB Silverado
84 LWB Custom Deluxe
Grey 87 is offline   Reply With Quote
Old 08-13-2003, 11:49 PM   #17
boataddict26
Thanks Grey. I have made up my mind (again) I am going to go with grey primer. Thanks for all the input.
Old 08-15-2003, 01:59 AM   #18
CT-Truckster
what if you used black primer while you were doing your bodywork, might be easier to see how straight your gettin it like grey 87 said. then when you got ready to paint you could primer it gray, would there be anything wrong with doing that?
Old 08-15-2003, 08:30 AM   #19
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I use suede paint
I could never settle for a primer color myself. I need different.
Also, if you don't use epoxy primer, or paint, it will rust, that's for sure.
My wife and I were at a car show in 2001, when this guy walks up and starts asking me how I did my car. I explained it to him, and he took a picture and left. That picture was in Rod & Custom magazine. He was their photographer.
Suede paint rules, and it never deteoritates like primer. Yes, it's the same color as my truck, it's just flat. Give it a try, you'll love it!
