Old 08-23-2014, 07:57 PM   #1
jackson
door regulator springs 49
been searching the net for just the springs , new or old . any clues fellas
jackson is offline   Reply With Quote
Old 08-23-2014, 08:35 PM   #2
Iceburgh
Iceburgh's Avatar
Re: door regulator springs 49
http://www.lmctruck.com/icatalog/ca/full.aspx?Page=14
#5
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 08-23-2014, 10:20 PM   #3
jackson
Originally Posted by Iceburgh View Post
all I see there is the hinge spring . I need the window regulator spring. it helps roll the window up. my bad ,I wasn't that clear . thanks anyway
Old 08-24-2014, 04:42 AM   #4
msaintg
msaintg's Avatar
you can buy just the regulator, but I don't know of any springs that help roll the window up
msaintg is offline   Reply With Quote
Old 08-24-2014, 09:10 AM   #5
jackson
its a spring right under and inside the window crank. I read somewhere that it helps give a little leverage on the roll up. wish I could post a pic
Old 08-24-2014, 09:57 AM   #6
crossfire84
crossfire84's Avatar
go to classic chevy truck parts, look up part #18-781
hope this is what your looking for.
LIL ERV the 50-3600
396 BBC stroked to 415 cid
Richmond 6spd over drive
C4 rear
Porter built a arms
Never give the Devil a ride,because he'll want to Drive!
crossfire84 is offline   Reply With Quote
Old 08-24-2014, 10:48 AM   #7
jackson
the one im looking for is the bigger one looks like the18-881 but my original
looks different than the 18-881
Old 08-24-2014, 10:19 PM   #8
Dustint
I just went through a window regulator repair on both driver and passenger sides. I believe the spring you are searching for is the one that coils around and hooks against the window regulator shaft that the handle attaches to. Although I'm not aware of where you can get one, if there is any question in the quality of your other parts of the regulator assembly it would probably be a worthwhile investment to just buy the assembly. I can tell you that installing the spring with all the other parts intact is a pain, took me a pair of vise grips and channel locks to get enough tension on it to get it back into location on one of mine that fell out. Obviously a time vs money thing, but just swapping in a new regulator assembly would be a 30 minute job for all new parts and less head aches for a little more money, the route to go in my opinion where you may need more than one part, or more than one part may be in okay shape but not great.
Dustint is offline   Reply With Quote
Old 08-25-2014, 08:45 AM   #9
jackson
I didn't know that little spring was that much of a bear, thanks buddy
Old 08-25-2014, 11:07 AM   #10
wolffcub
wolffcub's Avatar
Just about a month ago I was repairing all the components on my doors. I bought 2 new window regulators and went to go install them but the arm that lifts and lowers the window was way out of whack and did not line up at all with the bottom of the window. The arm was favoring the outside of the door by about 1.5 inches for both doors. I could have heated it up and bent it in to match the original one but instead i just took the time to fix the old ones. They actually still crank better then the new ones that were so tight.
wolffcub is offline   Reply With Quote
Old 08-25-2014, 03:59 PM   #11
mr48chev
mr48chev's Avatar
Chevs of the 40's shows this one but it doesn't look like what I thought it should,
https://www.chevsofthe40s.com/detail...r_Spring_.html
My ongoing truck projects:
