Old 08-23-2014, 10:18 PM   #1
Baddad1911
72 k 10 fleetside bed
Hi guys , this is my first post and am a bit lost as to the remounting of my bed. I bought the truck in pieces partialy done as a frame off. The bed is almost done but im wondering if the fleetsides sit directly on the frame or are there mounting pads like the stepsides ? If there are can someone tell me where to find them. Lmc only shows them for the stepside beds so i am a bit lost. Seems like something should go in between but since i bought the truck apart i could use some advice. Thanks in advance for any help
Baddad1911 is offline   Reply With Quote
Old 08-23-2014, 10:21 PM   #2
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: 72 k 10 fleetside bed
My K20 bed was set right on top of the frame from GM. I did use the square thin asphalt spacers when I did the rebuild and these did not noticeably change the body lines. Good luck with your build and welcome!
Old 08-23-2014, 10:29 PM   #3
Ironhorse
Ironhorse's Avatar
When I pulled the bed from my '71K10 it also was sitting on the bare frame mounts but when I re-installed I used rubber pads between the frame mount and the bed. Think I bought them as a " kit " but don't recall who I got them from, been to long ago.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 08-23-2014, 10:53 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
I have never used anything when mounting the beds on my builds. I haven't noticed any squeaks or any problems doing it that way.
LockDoc
Leon
