HELP !!! trans id.
Ok i just bought a motor and trans that i wanted for my 66. The guy told me that it was a 250 inline 6 with a 700r4 trans. but i dont know! Can some one help me? I tried looking up the cast numbers but not finding out much. so here is what i do know.
Cast number on side of case 8663548 Has a "K" on bell houseing also a MD 8 on side. Aslo has the arch on side of case through top cooling line Has a square plug on drivers side toward rear (4 prongs) On passenager side a cable running up to carb ( was told it was kickdown) Under tail shaft is a simi circular thing with another 2 prong plug. When i bought it guy told me it had cable style for speedo. well i cant find it. he said he had it in a 66 this is why i bought it for mine. Also cast number on side of engine block is 3921968 is this a 250?
live like you are dying ![]() |
![]() Join Date: Jul 2007
Re: HELP !!! trans id.
It sounds like an 8os 4X4 K case 700r4 It has a throttle pressure cable not a kickdown cable. You will need a adapter on the throttle linkage to properly run the trans.Bowtie overdrives sells them for a Quadrajet 4 BBL. I do not know which others they may have. They have a cool display that shows the trans pressure valve with the adapter and without. If you run without it will in time ruin your trans since it is not applying full pressure to the trans. The 700r4 was originally on a 1987 vehicle with fuel injection so the throttle geometry is different. The K case is said to be stronger and usually had a cast aluminum bell housing lower cover with supports that ran to a plate under the motor mounts . This helped support the trans bell housing.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yes that does sound like a 700R4, and the good K case at that. However that 'kickdown' cable is not a kickdown cable. That is the TV cable. If it is not connected properly to the carb linkage and the trans pressures not correctly adjusted, that trans is either burned up or close to it. Not very many people correctly setup the TV cable on a I6 engine since it is a bit difficult. To my knowledge, it has to be fabricated sinced no one makes the kits for the I6.
The semi-circular piece under the tailshaft with the 2 prong plug is for the electric speedo.
The guy i got it from said it shifted through all gears and overdrive great. guess he could have been lying about just to sell, ill try to take a pic of the cable hooked to carb and post. im hoping this wasnt a waste of money. both motor and trans was supposed to have been just rebuilt.
The engine comes up as a 1966-76 230 or 250 they both share the same casting numbers. The plug on the rear of the trans is a speedometer drive. I believe you can get an earlier gear driven adapter to replace it with. The trans could be new and as a core is worth about $ 250. I have them rebuilt by a professional and as a carry in it runs me about $650. If it is built correctly it will probably be fine. I do not know what you paid but if you decide to install it you should use a rear gearing of 373 for a good all around gearing.
Thanks jurassic-1 & captinfab. that helps me narrow the engine down. i got to lookin last nite online and found a kit to switch the elec speedo back to gear speedo. and my hears in rear are 373 so hopefully it will be all good. im still gonna try to post a pic of the tv cable where it attaches to carb. thanks
Here is pic of where tv cable attaches to the carb.
![]() Join Date: Jan 2011
Well that is not going to work and if he ran it that way I would say tranny is toast.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
You will probably need to get one custom fabricated to fit the six cylinder engine since the 700R4 would have been behind a 4.3 V6 or V8 engine. Here is an article to give you a better understanding of the operation of the cable. http://www.tvmadeez.com/article/index.php This is on the Bowtie Overdrives web site.
You can put standard speedo gears in that transmission to hook up your speedo cable with out having to use any electrical adapters
Thanks everyone for all info. that link will be very helpfull when i go to try and set it up.
60-66 Nut
I agree. That's not even close to what it should be.
#13 |
![]() Join Date: Sep 2006
I got scared looking at that...
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#14 |
Ok thamks chevy fleetside i will do that.
