Old 08-24-2014, 01:20 PM   #1
Laid_Out_50
Laid_Out_50's Avatar
Freeway Speed in a 3 Speed
I'm running a TH400 and on the freeway I do 65 at about 2900rpms 3.73 gears on 27" tires. What are some options to help lower the rpms and still be about to do freeway speeds
Laid_Out_50 is offline   Reply With Quote
Old 08-24-2014, 01:45 PM   #2
PDW HOTRODS
PDW HOTRODS's Avatar
Re: Freeway Speed in a 3 Speed
Get an overdrive trans, gear vendors overdrive unit, or change rear end gears.
PDW HOTRODS is offline   Reply With Quote
Old 08-24-2014, 02:03 PM   #3
Dan in Pasadena
Dan in Pasadena's Avatar
Cheapest is to get lower (higher numerically) rear end gears. Was about to post a link to Patricks Truck Parts until I realized you probably already have a newer rear end in it.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 08-24-2014, 02:08 PM   #4
Laid_Out_50
I've been told to swap out the gears to 3.23 or lower
Old 08-24-2014, 03:03 PM   #5
mr48chev
mr48chev's Avatar
There are a number of charts on the net that you can input engine rpm, tire size and gear ratio to calculate what would work best.
I was going to say just up the rear tires size to something like 29.5 dia but after reading a couple of your other threads that is most likely out and you will have to do the rear gear thing, swap to an overdrive trans or spend 2500 bucks on a gear vendors od.
I'd think that swapping rear axles or rear gears is probably your simple option.
Play with this from Randy's ring and pinion and you can figure out what gear ratio would work best for what you want to do and the rpm you want to run down the freeway at. http://www.ringpinion.com/Calculators/Calc_RPM.aspx
My ongoing truck projects:
Old 08-24-2014, 03:09 PM   #6
Russell Ashley
Russell Ashley's Avatar
Would a 700R4 bolt in? I think I'd be looking into that.
Russell Ashley is offline   Reply With Quote
Old 08-24-2014, 04:06 PM   #7
Laid_Out_50
No it wouldn't I'm running a Buick Nailhead engine that has a different bell housing pattern weird I know
So after finding a calculation online to figure out rpms with various r&p gears here's what I found
Gear Ratio x 336 (common member for auto trans with lock up converter 355 without) x Speed x Final Transmission Gear Ratio
Gear Ratio's at 70mph
3.55= 3092rpms
3.31=2883rpms
3.27=2848rpms
3.15=2744rpms
3.08=2683rpms
2.73=2378rpms
I was thinking 3.08 gears
Old 08-24-2014, 08:29 PM   #8
_Ogre
_Ogre's Avatar
i run a 3.27 gear and a 700r4, i don't have a tach but it feels like i'm idling at 55 mph
shop air compressor timer
Old 08-24-2014, 08:32 PM   #9
dfrank
dfrank's Avatar
I run a th350, 4.10 gears and 35in tires and get about 2800 rpm at 70mph
dfrank is offline   Reply With Quote
Old 08-24-2014, 08:36 PM   #10
Sethmark
I'm running a 350 with a th350 and a 2.72 rear end ratio. I leave a LOT on the table performance wise, but I can roll at 75 at about 2300 rpm.
There's a balance to be had. I'd prefer to be a little closer to 3.23 myself.
Sethmark is offline   Reply With Quote
Old 08-24-2014, 10:50 PM   #11
mr48chev
mr48chev's Avatar
If the Nailhead is close to stock the ideal setup would be to figure out what gear ratio would match up with the stock rear end and tire size of the car the engine came out of so you were geared out to match the donor car's rpm at road speed.
Most of the mid 50's early 60's Buicks were real road burners that the engines didn't work hard in until you got up over a hundred. I think you are right in the ballpark with 3.08 or 3.23 though.
Old 08-27-2014, 12:39 PM   #12
yossarian19
Taller rear tires will help, too.
Note that if you change either the rear gears, the trans *or* the tire size, your speedo gets off calibration.
The best answer is going to be an OD trans. It's no coincidence that overdrive transmissions came into vogue with the Interstate Highway system.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 08-27-2014, 01:01 PM   #13
Keith Seymore
Keith Seymore's Avatar
Drive slower.
I try to hover around 60-60 mph when on the freeway and limit my freeway drives to something other than rush hour. I also find I enjoy traveling the secondary roads more than I do the superhighways, both because of the greenery and because the outside air seems cooler.
Relative to a trans swap with a Nailhead: you might see if there is an adapter commercially available. Sometimes they are a bit pricey but can enable some of these less common combinations.
http://www.transmissionadapters.com/Pricing.htm
I used one of these to put a TH400 in my '63 Grand Prix (...of course, now I wish I had done an overdrive trans of some sort).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 08-28-2014, 02:11 PM   #14
_Ogre
_Ogre's Avatar
just ran these numbers through a rpm/gear calulator with 3.27 gear, .70 4th gear and 28 inch tires
truk is idling at 55 mph, truk runs 1511 rpm; at 70 mph it is 1940 rpm and at 100 mph it is 2747 rpm
no wonder i get 20 mph cruising at 80 mph
Old 08-28-2014, 02:19 PM   #15
_Ogre
_Ogre's Avatar
Originally Posted by Keith Seymore View Post
Drive slower.
silly man
Old 08-28-2014, 03:26 PM   #16
Keith Seymore
silly man
LOL.
Yah. Around here if you drive too slow you'll get run over.
K
1979-1986
1986 - 2019
Old 08-28-2014, 05:29 PM   #17
1project2many
Homegrown / hotrodder method from the days of the Nailhead:
Install 2nd 3 spd trans backward and connect only 2/3 arm shift linkage. You'll have direct and OD with the OD equalling .59:1
Searches for brown-lipe, brownie, US gear, watson, Ranger, & laycock auxilliary transmissions will all produce interesting options.
Also, as mentioned early 3spd w/ OD trans is still available. This trans is not bulletproof... original wiring actually cut ignition momentarily during shift to prevent parts breakage.
1project2many is offline   Reply With Quote
Old 08-28-2014, 07:55 PM   #18
Highsider
Highsider's Avatar
Wow. Several things here that I did not know, or had not thought about for over 40 years!
Thx.
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 08-29-2014, 09:15 AM   #19
FirstNation
FirstNation's Avatar
Hey Dan in Pasedena- "Cheapest is to get lower (higher numerically) rear end gears." Help me out here, i'm confused- aren't lower rear end gears also lower numbers?
1953 Chevy 210 convertible, 1955 GMC pickup, 1957 GMC Suburban Carryall
FirstNation is offline   Reply With Quote
Old 08-29-2014, 10:19 AM   #20
sstock
sstock's Avatar
yeah, Dan got it backwards. To lower the rpms you need lower numerically number which are taller gears not shorter.
sstock is offline   Reply With Quote
Old 08-29-2014, 10:54 AM   #21
_Ogre
_Ogre's Avatar
nice first post, sstock
Old 08-29-2014, 12:19 PM   #22
OrrieG
OrrieG's Avatar
Thx.
I learned to drive in a 50 Willys Wagon with 3 speed OD trans, when shifting to OD you had to remember to clutch or it made interesting noises and my Grandmother beat me with her hat saying "Dammit Patrick you're going to break it and we will have to walk home".
OrrieG is offline   Reply With Quote
