Old 08-24-2014, 07:18 PM   #1
dhughins
dhughins's Avatar
What goes in this hole?
My 84 has a old crate 350 with a Rochester 2jet. On this block off plate there is a hole causing a vacuum leak. What goes there or what can I put there? I hope you can see it well enough.
dhughins is offline   Reply With Quote
Old 08-24-2014, 09:40 PM   #2
v30crewcab
v30crewcab's Avatar
Re: What goes in this hole?
that goes to the back of the carb right under the aircleaner on my motor.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 08-24-2014, 10:30 PM   #3
Skunksmash
Skunksmash's Avatar
... I'll tell you when you're older
Skunksmash is offline   Reply With Quote
Old 08-25-2014, 02:26 AM   #4
dhughins
dhughins's Avatar
Is there supposed to be some kind of fitting in it? I couldn't tell if the hole was threaded, it was getting dark. Will try to see tomorrow.
Old 08-25-2014, 08:53 AM   #5
SkinnyG
SkinnyG's Avatar
It's just like the metal tube below it. It slips into the hole, but goes around to the back of the carb, and connects to a hole at the top edge of the air horn.
Inside that thingie is a tube that gets heat from the exhaust crossover. The choke housing has a wee bit of vacuum to it, which draws air through the whole thing - fresh air from the air horn, through the (missing) tube, into the hot cross over, and then into the choke housing.
Without it, the choke might never turn off.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 08-25-2014, 11:34 AM   #6
dhughins
dhughins's Avatar
Thanks skinnyg. Would it be possible to get a picture of the line? Does it have fittings on both ends or what? This truck ran right the day I bought it drove it home then started having problems. I had a shop start to work on it and they didn't know what they were doing so I towed it home and have been fighting vacuum leaks ever since. I took Carb off and rebuilt, but never noticed that hole till I started messing with it over the weekend. Is there a fitting that goes in hole and then a rubber vacuum line from there?
Old 08-25-2014, 11:54 AM   #7
dhughins
dhughins's Avatar
Went and looked in daylight. I see there are no threads. Looks like a fitting should be pressed in ?
Old 08-25-2014, 05:26 PM   #8
v30crewcab
v30crewcab's Avatar
yep just presses in. not sure how tight, haven't taken one out.
71 longbed 5.3 4l80
Old 08-25-2014, 06:21 PM   #9
SkinnyG
SkinnyG's Avatar
Mine is just as you see above.
The connecting hose at the air horn can be simple rubber. The connecting hose at the choke housing should be silicone so it doesn't melt (it's going to get very hot).
You should have a gasket for the bakelite choke cover, as well as a wee plastic double-spigot-spacer that connects between the choke housing and the carb body (the seal for the vacuum source).
Check all vacuum ports on the carb and make sure none of them are unplugged (don't forget the one at the back of the carb base for the hot air riser on the air filter).
Make sure the secondaries close all the way.
Make sure the primaries are as closed as you can get them (you don't have a rowdy cam, do you?).
When you assembled it, did you check for warpage at the air horn as well as the carb body? These are almost always warped by people over-tightening the carb bolts. Another potential source for leaks.
Old 08-25-2014, 06:31 PM   #10
Gotenntitans
Gotenntitans's Avatar
I knew when I saw the thread title someone was gonna getcha! GTT
GoTennTitans
1987 GMC Sierra
1990 GMC Sierra (stolen)
2003 Chevy Silverado
Gotenntitans is offline   Reply With Quote
Old 08-25-2014, 09:43 PM   #11
dfrank
dfrank's Avatar
Throw it as far as you can and get a holley.
dfrank is offline   Reply With Quote
Old 08-25-2014, 10:20 PM   #12
SkinnyG
SkinnyG's Avatar
Because of a missing hot-air choke tube? Interesting....
Old 08-25-2014, 10:45 PM   #13
Just call me Sean
Just call me Sean's Avatar
Well... I would ditch it for a Quadrajet with electric choke and stock type intake, but I see what he's getting at.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-25-2014, 10:52 PM   #14
dhughins
dhughins's Avatar
Thanks for the answers and pictures that helps alot. now just gotta figure out a solution for it. I'm thinking I might be able to put a rubber vacuum fitting in there and run a line up to carb and see how it goes. the 1 on bottom in that picture has a piece coming out of plate that line goes in but the other 1 doesn't. I wonder why? you reckon just some 3/8 fuel line and bend it will sit down in there?
Old 08-25-2014, 11:24 PM   #15
SkinnyG
SkinnyG's Avatar
No - don't use rubber at the heat-crossover plate, it gets too hot. Use metal.
If you cannot find the correct line at a wreckers, use a piece of metal fuel or brake line or whatever will fit snug. But metal. The metal line you are missing needs to be connected to the back of the carb air horn. This connection can be rubber (see top left of the picture).
An electric choke thingie would be the best fix, especially if you're running headers and/or have deleted the heat-riser valve in the passenger side exhaust manifold (this closes when cold, and forces passenger-side exhaust through the intake and out the driver's side).
Old 08-25-2014, 11:40 PM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
closer to 1/4 tube inch i'd say
mines like that,when those screw up ,I tie off the choke till i can rule it out.
as the leak gets worse, so does the mileage
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-26-2014, 06:13 PM   #17
dfrank
dfrank's Avatar
No, not because of a missing hot air choke tube, but because a holley is superior to a rochester 2 jet. Especially on a 350.
Old 08-26-2014, 10:37 PM   #18
buddy_1
buddy_1's Avatar
I found a good pic for you.
Look here for a universal repair kit. http://shop.advanceautoparts.com/p/d...ontent=5013143
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 08-27-2014, 05:49 PM   #19
dhughins
dhughins's Avatar
thanks buddy_1. the picture and link were both awesome. i ordered it from amazon for 5.99 should have it in a couple of days.
Old 08-27-2014, 10:28 PM   #20
buddy_1
buddy_1's Avatar
Glad I could help, Buddy
Old 08-27-2014, 11:22 PM   #21
Nin92
Nin92's Avatar
Made me lol
Nin92 is offline   Reply With Quote
Old 09-02-2014, 03:07 PM   #22
dhughins
dhughins's Avatar
I got my hot air choke repair kit that's linked a couple post above. Can anyone tell me how to use it?
Old 09-03-2014, 02:59 AM   #23
y5mgisi
Second Chance Program
y5mgisi's Avatar
Just FYI, those are super easy to convert to electric choke. Then you dont have to mess with the air tubes. Google something like "hot air quadrajet to electric choke".
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
