Cutting up old Cab / Extra parts
I am working on repairing a cab I bought from another board member that needs less work than my original cab. I will need to get rid of my first cab soon, so if anyone needs any pieces, let me know. I will post pics as soon as I get to my PC (working on an Ipad). I have to make space in my garage and help pay for some of the complete floor pan I just ordered.
I will list parts in this post, and add photos of the cab and other leftover parts below. All parts are plus shipping. 1. Dashboard - REDUCED TO $60 - Anybody interested?: This is my first time removing a dashboard, and I think I did an okay job. The radio part was cut out by previous owner. Dash has small hole in lower right corner. Might need a little fixing where the dash meets the cowl. I was not sure what to ask for this, so please let me know if the price is not where it should be. 2. Tabco driver's side rear Cab Support (new) - $10 (Tabco price is $14.50). 3. Triplus LH Floor panel new - $15 (similar panels sell for $26 new). SOLD 4. Inner Rocker Panel patch (I think it's Triplus also) - $5 SOLD 5. Triplus Cab support RH (I believe it's the rear support) - $10. 6. Cab Support - Slip On Covers, Triplus brand, don't know if anyone will actually want these. - $7 each. 7. The back half of the floor pan is pretty solid. I believe the cab supports are shot, but the floor is still pretty nice. If anyone is interested I will figure out a price. 8. Anyone interested in an outer roof?
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 Last edited by DD1; 09-12-2014 at 09:53 PM. Reason: Added item |
Re: Cutting up old Cab / Extra parts
How much for the Triplus LH Floor panel and the Inner Rocker Panel patch shipped to 27892?
Thanks, chubinit |
![]() Join Date: Mar 2011
low or high hump?... need low hump patch PO cut big hole for floor shifter
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
#4 | |
Pics: Tabco Rear Support & Inner Rocker Panel, Triplus floor pan front and back shot,
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 |
#5 | |
You are still online as I am typing this (10:44 EST); I'll get a couple of quick pics and edit this post. Okay, here are the pics. I have not cleaned the cab out so, excuse the mess. The hump looks to me like it's in pretty decent shape. There is a small hole for the transmission. It is dirty, there is rust dust on it from removing the dashboard. I can clean it up tomorrow and send another pic if you want. If you are interested, we can figure out a price, and I will need to know exactly where to cut, and then I will probably still add a couple inches. Thanks!
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 Last edited by DD1; 08-24-2014 at 10:57 PM. Reason: Added photos |
#6 | |
Dashboard pics:
Other parts of the cab are up for grabs as well, as long as I don't need it on my replacement cab. This cab is a Non-A/C, the new cab is an A/C cab, so I won't be needing some of the heating parts.
Here are some rough pics. I clean the cab and get some better shots tomorrow.
#9 | |
thats going to work for me, ill take some pics and measurements send to you and LMK what you need for it
THANKS..... jz Quote:
looks like 8 by 10 will give me enough LMK if you need any other pics
Wow. That is a big hole. Would you please send me a pic of your hump that is a bit further back. I just need to see more of the floor to make sure I cut the right area.
I sent you a PM.
#13 |
hope these help
#14 |
That works. I read your last PM. I'll mark it up, post some pics, cut it up and post some more pics. We can touch base after Labor Day.
#15 |
thanks enjoy the holiday......
#16 |
How much for the center section of the cab back wall from the bottom rear window molding seam to the floor and about 2 or 2.5" wide?
72 Chevy Cheyenne K10 4x4 LWB, 4" lift kit, 350/350/NP205, rebuild in progress. |
#17 |
what about the driver side roof section at the windshield?
build thread - 1972 C/10 "Ethyl" 1974 C/10 " Paw Paw" C/10 Club Louisiana ![]() instagram - @esso_c10 @projectpawpaw |
#18 |
How does the upper rear seam look inside above the pass door look? need a patch to fix mine. I can get pics this afternoon.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase 1955 Chevy Stepside "Dudley" My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288 1972 Chevy C10, Project "Chevro~Layed out" Nether Storm Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523 |
#19 | |||
Are you talking about inside the cab or outside? Inside is not that great. Outside is decent. Quote:
___________________________________________ Darien 1971 C10 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=502964 Last edited by DD1; 08-25-2014 at 06:22 PM. |
#20 |
Here are pics for:
5. Triplus Cab support RH (I believe it's the rear support) - $10. 6. Cab Support - Slip On Covers, probably for the front, Triplus brand, don't know if anyone will actually want these. - $7 each.
#21 |
I'll get a picture this afternoon of the patch I need and post it for you. It kind of hard to explain. Thx for looking.
#22 |
PM sent DD1.
#23 |
#24 | |
I am sorry to take so long, but it's been really difficult trying to box this thing up. The floor panel is a rough shape to work with. I am going to try and create a custom box and get a quote. Let me know if you are still interested. Thanks!
#25 |
What are the kick panel/air vents like?
I need the whole left side. ![]() |
