Old 08-09-2003, 06:58 PM   #1
Nvbowtie
Nvbowtie's Avatar
Thoughts on this ???
http://www.chevytalk.org/threads/sho...5&o=31&fpart=1
penny for your thoughts
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 08-09-2003, 07:38 PM   #2
gldevall
gldevall's Avatar
The trans cooler and run gas through sounds like a good idea. But I don't know, sounds funny. Like it may be kinds risky or something
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 08-12-2003, 01:02 AM   #3
jimfulco
My 72 Nova w/Qjet came with a carb gasket about 1/4" thick & a stainless heat shield (same size as gasket) between the carb & the gasket. Mine never vapor-locked even if the A/C was on & the coolant was running 230* or so. It would act up only if I stopped the motor for 5 minutes or so & then tried to drive onto the interstate in a hurry. The shield & thick gasket are available at a parts store, but be sure the gasket has hard plastic bushings around the bolt holes. Otherwise you can easily warp or break the throttle plate when you tighten it down. My Dad said they used to put split fuel hose around the metal lines for insulation & then wrap that with aluminum foil to reflect heat.
jimfulco is offline   Reply With Quote
