Old 08-25-2014, 09:23 PM   #1
Dale99
Part Out/Sell Whole, 67 c10 2wd long rough shape
I picked up a 67 c10 2wd with a very rough body. Grabbed a few parts for my dads truck, not much I could use on mine. It has to be gone by Oct 1st. I work during the day, so picture taking and parts pulling will be in the evening.
1. Since the body is so bad other than the cab, I'm going to offer patches of fenders. It is a steel floor bed, but is quite bad. Not sure I can get a good patch, will have to look closer.
2. :edit: cab is sold.
3. I need to keep this a rolling chassis as long as possible. If you need suspension parts, I can do that at the very end.
I also have a pile of other parts from past situations, they are forsale as well. Parts are located in 72120, and would like to try and ship "if it fits it ships" as much as possible.
Still here and good....
engine last ran in 2002, said it ran good
3speed trans, said they had it rebuilt at some point
air cleaner (in accessory pic)
seat frame is here
Parts I know are bad/gone.....
headlight bezels
park lights
backup lenses
cluster
grill shell
1 grill ring
front bumper
door handles/cranks
door panels(1missing, 1 damaged)
all body panels have some sort of damage.
cab
rear springs
carb
gm goodwrench VC's in misc parts picture gone.
2008 Sierra k3500 LMM
1994 s10 blazer 4x4
1991 Camaro Vert Rusted in Half RIP
1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364
1967 C10 L6/3tree(dads truck)
Dale99 is offline   Reply With Quote
Old 08-25-2014, 09:35 PM   #2
flashed
Re: Part Out/Sell Whole, 67 c10 2wd long rough shape
How much for the one lonely hubcap shipped to Ga 30114 ?
flashed is offline   Reply With Quote
Old 08-25-2014, 09:38 PM   #3
Dale99
It has some dents, could likely be hammered out. If it will fit in the medium box, I would do 20 to your door.
Old 08-25-2014, 09:39 PM   #4
michael bustamante
michael bustamante's Avatar
interested in the window crank handles if those are still there as well as the dash knobs if they are the deluxe. and how is that passenger fender?
1967custom
michael bustamante is offline   Reply With Quote
Old 08-25-2014, 09:45 PM   #5
Dale99
window/crank handles were broken or used on my dads truck.
not sure which knobs are deluxe, can you post a pic of what your looking for? (edit these knobs are solid black, I don't think that's deluxe??
pass fender has typical rust front and rear, plus dents along front edge
Old 08-25-2014, 09:50 PM   #6
muckmuck
Junior Member
muckmuck's Avatar
Is that a sport mirror backing plate mixed in with the other parts? If so, I'm interested in a price shipped to 89044.
muckmuck is offline   Reply With Quote
Old 08-25-2014, 09:50 PM   #7
michael bustamante
Surface rust or eaten thru and pitted?
Also the deluxe knobs will have the srainless center and ridges along the edge like a quarter. I know i need more. Ill have to go look at my truck
1967custom
Old 08-25-2014, 09:54 PM   #8
Dale99
muckmuck, yes you are correct. It is heavily rust/pitted but still quite solid. I would do 8 to your door in small usps box.
Michael, full eaten thru front and rear lower. That is not the knobs I have, sorry.
Old 08-25-2014, 09:58 PM   #9
Dale99
muckmuck.. Is this also the correct side you need?
Old 08-25-2014, 10:00 PM   #10
muckmuck
Junior Member
muckmuck's Avatar
I actually need both sides but that looks a little rough. I may need to pass for now...
Old 08-25-2014, 10:02 PM   #11
Dale99
Michael....
Old 08-25-2014, 10:03 PM   #12
Dale99
Understand, thanks for looking!
Old 08-25-2014, 10:48 PM   #13
Maddoxdb
Maddoxdb's Avatar
Price for carburetor and complete fuel line from carb to fuel pump shipped to 73644 please. Thanks, Dustin
Maddoxdb is offline   Reply With Quote
Old 08-25-2014, 11:12 PM   #14
bertvert72
bertvert72's Avatar
how much for the electric fan ?
Bret
Here's a link to my build
http://67-72chevytrucks.com/vboard/s...d.php?t=577889
bertvert72 is offline   Reply With Quote
Old 08-25-2014, 11:53 PM   #15
ScottH
ScottH's Avatar
Need a 6 cyl upper alternator bracket. If u have one how much shipped to 08753?
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 08-26-2014, 12:35 AM   #16
michael bustamante
Dang i was hoping the cup would be good on the fender. Thank you though.
1967custom
Old 08-26-2014, 02:16 AM   #17
UP GRADE
one set closer
UP GRADE's Avatar
How much for the ignition bezel?
UP GRADE is offline   Reply With Quote
Old 08-26-2014, 07:05 AM   #18
Dale99
maddoxdb. The hard fuel line stops slightly before the pump and turns into rubber. Is that correct?
bertvert. I was thinking 20plus ride. It is 12" summit brand, flows 1100cfm.
scott, should still be there. Will verify tonight.
Michael, thanks for looking.
upgrade, a few dollars plus ride. Will get better pics tonight for you.
Old 08-26-2014, 08:48 AM   #19
Maddoxdb
Maddoxdb's Avatar
I believe that is correct but after thinking on it I think I just need the carb. That should cheapen shipping up a bit too. Thanks, Dustin
Old 08-26-2014, 12:46 PM   #20
waylonbud
What is your price on the cab with the doors. Doors dont need to be complete but I would like the outer door handles.
Thanks.
waylonbud is offline   Reply With Quote
Old 08-26-2014, 02:01 PM   #21
UP GRADE
one set closer
UP GRADE's Avatar
Ok thanks.
Old 08-26-2014, 02:38 PM   #22
59bones
59bones's Avatar
Looks like a 292. I am interested in the head. Any idea when the last time this thing ran? Please provide a price with shipping to 60109.
Thanks for your time.
59bones is offline   Reply With Quote
Old 08-26-2014, 06:28 PM   #23
Dale99
Waylon bud... cab, cab windows, doors, door windows, outer handles, crank assy, steering column, glove box, title, BOS. I will do 150 you come get it. 250 will get the the whole truck minus rims and gas tank.
59bones. I'm not sure how to tell engine size on I6. Where is it and I will verify engine size before I pull the head. Last ran 2002.
About to pull parts/take pics of all other stuff.
Old 08-26-2014, 06:55 PM   #24
waylonbud
Hi Dale,
I will take the cab for $150 for sure. Do you need $ to hold til I pick up or how do you want to do it? I work almost every Sat. and it will take me 8-9 hrs to get to Little Rock. Wish I had better flexibility with work, but usually Sun is all I have. I guess I could complain about not being able to buy parts, Haha.
Old 08-26-2014, 06:56 PM   #25
waylonbud
Hi Dale,
