Old 08-25-2014, 09:32 PM   #1
IHutch5R
62' rear coil spring removal help
Just got 4" rear drop coils for my 62' C10 SWB. Will the stock springs come free enough to remove by lifting the rear end of the frame and unbolting? If anyone can share how they did theirs or tips on getting them out it would be appreciated, so I dont kill myself in the process. Thanks!
IHutch5R is offline   Reply With Quote
Old 08-25-2014, 09:52 PM   #2
ls60apache
Re: 62' rear coil spring removal help
hello the rear springs are a lot safer than the fronts.take the spring bolts and retainers loose at the control arms take loose shocks and jack up till all tension is off,then take out upper spring bolts and retainers..reinstall in reverse order good luck!
ls60apache is offline   Reply With Quote
Old 08-25-2014, 10:10 PM   #3
LVPhotos
LVPhotos's Avatar
I used a 4x4 across rear frame rails. Lots of PB Blaster or creeping lube not WD40. Lower bolts first, jack free, upper bolts. Reverse install.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-25-2014, 10:10 PM   #4
LVPhotos
LVPhotos's Avatar
I used a 4x4 across rear frame rails. Lots of PB Blaster or creeping lube not WD40. Lower bolts first, jack free, upper bolts. Reverse install. Assuming shocks not limiting droop.
Can you take a rear before and after measurement at rear frame rail? Mine was 17 and bags set at 11 inches.
Old 08-25-2014, 10:24 PM   #5
LVPhotos
LVPhotos's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1386799949
Old 08-25-2014, 10:24 PM   #6
IHutch5R
Thanks, and yeah I will let you know.
Old 08-25-2014, 10:27 PM   #7
IHutch5R
Awesome, thank you!
Old 09-21-2014, 03:14 PM   #8
IHutch5R
My before is measuring 22" right behind the rear shock
Old 09-21-2014, 08:47 PM   #9
IHutch5R
After came to 17" and my shocks are bottomed out, so i dont know if it will go lower with new shorter shocks. Any ideas on getting another inch or two out of the rear?
Old 09-21-2014, 09:47 PM   #10
LVPhotos
LVPhotos's Avatar
Blocks.
Old 09-21-2014, 09:50 PM   #11
IHutch5R
Blocks.
I can't find any blocks for a 62'.. they start at 63'.
Old 09-21-2014, 10:08 PM   #12
LVPhotos
LVPhotos's Avatar
Same thing. Especially if you have swapped rears. Measure holes.
Old 09-21-2014, 11:22 PM   #13
IHutch5R
Haven't swapped rear end..
Old 09-22-2014, 01:07 PM   #14
LVPhotos
LVPhotos's Avatar
Here is the issue of axle being pushed up and forward. The blocks will help. The block hole spacing will be the same. Same size axle tubes. Measure, Measure, Measure. New longer U bolts come with the block "kit".
Old 09-23-2014, 10:46 AM   #15
IHutch5R
Oh okay.. so you think the width of the u bolt holes are the same, so it should work? I wonder why they dont put that it will fit a 62' also?
Old 09-23-2014, 11:44 AM   #16
LVPhotos
LVPhotos's Avatar
"It's a conspiracy...man"
I have had this truck since 1998 ando pretty much had to make parts fit. There is little aftermarket support. That's why I chose Porterbuilt parts. Them and No Limit were the only ones with suspension. I might have #2 PB for '62
