Porterbuilt forward arms
Im thinking about running the PB forward series arms and the stage 2 deluxe rear. Along with 2 inch drop spindals and 15 inch steelies. Is anyone running a setup kinda like this? My truck is a 66 and curious if i can keep the front inner fenders and would just kinda like to see how its sits at ride height and layed out. Ive been trolling the pic thread for bagged trucks but no one really puts details of their truck.
#2 | |
Re: Porterbuilt forward arms
Right now I have 235/60r15 I think
That's a touch over 26" tall. I have a Dropmember & w/a 215/70-15 (roughly 27") on a 6" wide wheel I calculated I would have to clearance the top of the inner wheel housing slightly.
Final tire height, wheel width, & back-spacing will all have an impact. But the limitations of the front crossmember will likely prevent it from being an issue @ the 26" height. Worst case, they might require clearancing (small bump @ the top). Here's a great reference (& build).... http://67-72chevytrucks.com/vboard/s...postcount=1096
Thanks i have seen that, his truck is pretty sweet. I honestly wish i would have thrown some supremes on my truck. There was a thread on a baby blue truck I think Dino built that was running the same style set up i want but cant find it. It may have been delmo.... You look and read so much it all runs together
