Intro / brake help!
Heya everybody,
I used to have a 67 chevy project that went nowhere. I never really got into it because that's not really the model I like. It was more a purchase of opportunity. I sold that a while ago and have recently bought a 65' the year I've wanted since I was a little kid. I'm from Chattanooga Tn and Yadda Yadda Yadda I gotta problem. Soooo I'm trying to do the single to dual res master cylinder switch over that chief rocka did and posted on these very forums. I got the lines split and a new 67' MC bolted in and hooked up. It's a drum drum setup. The problem is that when I gravity bleed the brakes the front brakes don't drop after the air bleed. I get nothing but fluid and foam. The rears bleed normal ( pump pump pump hold bleed pedal drops air escapes repeat) when I take the truck around the block and stand on the brakes, the rears lock up and the front do almost nothing and it creeps to a stop eventually. I triple checked for leaks and can't find any. Any ideas? Thanks in advance for the help! |
Re: Intro / brake help!
Sorry forgot a pic http://tinypic.com/r/154avdf/8
Wheel cylinder leaking??
Jon S 1966 GMC Suburban 305 V6 Las Vegas NV |
Did u bench bleed the master cylinder ?
If you don't like this ![]() |
Hmmmm nope. Mc didn't come with a bench bleed kit. Thought I could get away with just bleeding at the line after I bolted it up.
60-66 Nut
![]() ![]() Join Date: Mar 2007
If your master is moving some fluid and you're not getting fluid at the front wheel cylinders, I would suspect collapsed hoses.
I'm getting fluid to the bleed valve. Could it be getting there but not to the wheel cylinders?
![]() Join Date: Aug 2013
there would have to be fluid inside the wheel cylinder, in order to come out the bleeder. theres 2 small ports inside the wheel cylinder one for the fluid from the line and one to exit the bleeder.
Are your wheel cylinders mounted with the bleed screw to the top ? If not u will never get the air out.
Yep mounted to the top.
I noticed my dad's 68' chevy which is also manual drum drum has a valve block right next to the MC. It came stock. Is that a proportional valve? He's got an extra one off a parts truck. I could try it out. |
60-66 Nut
No, that is not a proportioniong valve. It is simply a distribution block.
Do I need it?
#13 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
a distribution block would allow for a one ( or two) output MC to feed more than one WC.
Like a splitter if you will.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#14 |
#15 |
I did last time I checked...
How do I bench bleed without the fittings and hoses running back into the fluid? Am missing something aside from digits? |
#16 |
you do it like every old timer mechanic does it. stick it in a vise, push the piston in, put a finger over each port to seal it, release the piston, repeat
#17 |
Cool! Learn sometin new!
Thanks I think I'll take the mc off, bench bleed it reinstall, adjust the front brakes to make sure there moving out enough and rebleed from start to finish. Any body got tricks for adjusting the front brakes? Also what order should I bleed the individual wheels? Ice asked a few people and gotten different responses. Thanks again |
#18 | |
60-66 Nut
That is something that I disagree with, with most people. I always start with the left rear since that is the farthest from the master cylinder. Most will say the right rear is the farthest, and it is.....in a straight line. The rear brake line comes from the master or prop valve, across the front crossmember and then goes down the right side frame rail to the rear. Then it drops down to the differential, and across to the left rear wheel. That makes the left rear the furthest down the line from the master cylinder.
Start at the left rear, then right rear, right front and then left front. Quote:
