Old 08-26-2014, 12:49 AM   #1
toddshawii
1970 350 specs
I bought a 350 from a 1970 1 ton truck with 12 inch clutch. The Id # is V1025TBB. I have found that it made 255 hp from Factory. I cannot locate any other specs. If anyone can help I would appreciate it. I am looking for any info on torque, compression ratio or cam specs. Thanks.
toddshawii is offline   Reply With Quote
Old 08-26-2014, 02:15 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 1970 350 specs
TQ was a tad more than the HP rating. If it's a worn out 40 year old engine it will need a rebuild and all the factory numbers won't matter after that. If you're planning on installing it as is... I would plan on pulling it out again later on and rebuilding it.
Unless you're trying to rebuild it to exact factory specs for a 10-point perfect restoration.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-26-2014, 10:22 PM   #3
toddshawii
Re: 1970 350 specs
Gary
Thanks gary.... that was less than helpful. I fully understand the condition of my worn out motor and it's no where near needing a rebuild. Perhaps I just do things differently than you. I was looking for some specs to help with cam selection. I'm gonna cam my worn out pos. And run the dog poo out of if. Like I have been for the last six years. It will just be faster now.
But if I find a bunch of money I want to waste on unecessary parts I will run out and rebuild it. I'm not running at the track every weekend so stock worn out components will work, just fine.
