Old 08-26-2014, 03:31 AM   #1
64stepside831
64 stepside tire size
I will be lowering my 64 stepside 4" in front and 5" rear and I want to put some performance street tires on but I need to know what will fit and what you guys recommend. I have 6 lug wheels I think they are 16in. I'm pretty sure they are stock but I could be wrong
64stepside831 is offline   Reply With Quote
Old 08-26-2014, 02:39 PM   #2
GVDobler
GVDobler's Avatar
Re: 64 stepside tire size
Check out this website.
It's all about how to size a rim to fit.
https://www.rsracing.com/tech-wheel.html
Jon S
1966 GMC Suburban 305 V6
Las Vegas NV
GVDobler is offline   Reply With Quote
Old 08-26-2014, 04:32 PM   #3
forestb
forestb's Avatar
I have a set of 275/55R17 in the rear of my 62 with a 5 inch drop. They barely fit after rolling the fender. they are on a 17 inch wheel but if you go to discounttire.com they have a tire size calculator to figure out what that will look like with a 16 inch wheel and the same width and diameter. There is a thread on this sight called let's see some wheel and tire picks. I would find the size I like from there and then ask that person what size they are.
forestb is offline   Reply With Quote
Old 08-26-2014, 09:05 PM   #4
Lugnutz65
Lugnutz65's Avatar
Wheels come with different back spacing. If you have wheels with too much or too little back spacing, then the tires might rub.
So you MUST know what the back spacing is if you are gonna do this right the first time. Of course, duplicating someone else's exact setup will work too.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
