Old 08-26-2014, 06:40 AM   #1
64stepside831
performance exhaust system
I am looking to replace the exhaust system in my 64 c10 with a swapped 350 sbc. I like the sound of glasspacks so I would like some ideas for an H pipe set up. If I could also get a recommendation on a high flow cat that would be great. And some header ideas as well, I know they aren't part of an exhaust system but I'm looking for some at the moment and need opinions. I want a loud low rumble and high performance since I intend to take the truck on the drag strip. My thoughts were doing an H pipe coming out the sides, I just need to know the sizes and specs on the system since I don't really know what is best.
64stepside831 is offline   Reply With Quote
Old 08-26-2014, 10:15 AM   #2
PGSigns
PGSigns's Avatar
Re: performance exhaust system
For what your looking for I would run 40 series flow masters and 2 1/2" pipe. Pick a set of headers that best match your engine combination. The header manufactures can help with that. My guess would be 1 5/8 primaries and 3 1/2" collectors. I like a good coated header.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-26-2014, 11:04 AM   #3
LVPhotos
LVPhotos's Avatar
You don't need cats and unless you have 500 horsepower you do not need an H pipe. Two other threads started this week on headers check there and faq section for header #s. I run 2.5" pipe to Flowmaster delta 40s dumped in front of axle.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 08-26-2014, 01:39 PM   #4
66LSx
66LSx's Avatar
While some say you don't need an "H" pipe... they sure sound a hell of alot better with them. (You don't have all the backfire garble on decel/defuel)
I have spintech's and an H-pipe... see my build thread (page 6 or 7) for video and earlier (Page 2 or 3) for exhaust routing
1966 C10 SWB Fleet
5.3L LM7 Vortec / 4L60e Swap
1966 C10 w/ 5.3L/4L60e Build Thread
2012 GMC Sierra 5.3L 4x4 CCSB
66LSx is offline   Reply With Quote
