brake questions.
hey guys, I just swapped the crossmember up front on my 68 with a full disk set up from an 85. I was able to get all the lines and prop valve. I have shortened my frame, and purchaced a new line, and an adapter to hook up the rear brake line to the prop valve, so at this point, everything is plumbed. I am using the mastercyl, and booster from the 85 also.
my question is, is there anything I will need to do to the rear factory drum brakes to deal with the power brake booster I am installing, or should they be ok? The wheel cylinders are new and had been replaced right before I got the truck.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
![]() Join Date: Jan 2011
Re: brake questions.
Should be good to go.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
![]() Join Date: Mar 2011
As PG said, should be no problem...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
