drive lines...
Hey guys,
I was reading over a few threads about 1 piece drive lines and I read that there may be some other drive line options for a short bed. Can anyone elaborate on this? is there other vehicles with the same length as a swb? I thought I saw something about a ford ranger drive line?
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
Re: drive lines...
Other options besides a one piece prop shaft?
Well, you could have a two piece....or a "no piece" (lol). Those are the only options I can think of. The shaft type was determined by a bunch of vehicle characteristics (wheelbase, engine/trans length, rear axle ratio, vehicle top speed, plus any unusual driveline bending resonances) in an attempt to keep the shaft out of it's critical speed range. Vary any one of those items and it could move you from a one piece to a two piece or vise versa. I always use a one piece when I can, due to less mass and complexity. Unless the right shaft falls out of the sky your best bet is to simply measure up what you need and have it made locally. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#3 | |
Re: drive lines...
#4 | |
Re: drive lines...
Other than that - correct. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-27-2014 at 11:08 AM. |
the boat guy
Re: drive lines...
I had 2 different length driveshafts in my swb, about 2" different in length, they both fit properly and I didn't change any parts.
So without a length we have no way of telling you what other cars you need to go look under. Then let's say you found the perfect length driveshaft (unlikely) the forklift operator didt bend it (unlikely) and it wasn't ruined in an accident... you just spent a bunch of time looking for the right shaft that still needs ujoints and have the ballance checked. Seems a lot easier to me to just have a shaft built to your specs, reusing your trans yoke can save you a few bucks. So why do you need a new driveshaft?
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
