Old 08-26-2014, 08:26 PM   #1
Ryguy442
64 daily driver project in NC
Hey guys kinda new to the forum, been lurking for awhile and doing research for friends projects on here but now it time for my own. So my old lame every day car finally starting having some issues that I didn't want to get into fixing so it was time to buy something new. I hate newer cars I like having aiming easy to work on. I decided it was time for a truck, my old 95' gmc is still kicking but with well over 350,000 miles it's only a matter of time for that truck. I came across a 64 step side on Craig's list after test driving it a deal was made and now it's mine.
Ryan
Ryguy442 is offline   Reply With Quote
Old 08-26-2014, 09:08 PM   #2
Ryguy442
Re: 64 daily driver project in NC
I knew when I bought the truck it need some work to be a good driver, one major problem was the rear end. It had a 4.11 posi in it, that clunked really bad. Sounded like a bowling ball was trapped in there. So I tracked down a 71-72 rear so I could keep my 5 lug and it's a direct bolt in. Then new rear end has 3.07 gears which makes a huge difference.
I have also replaced the carb, it had a holley 750 on it, which was too big so a buddy of mind told me to look at the carbs summit has been offering. After reading the reviews I bought a 600cfm model.... I would recommend this carb to anyone, it's been great.
My problem right now is time.... I'm driving the truck everyday and it's doing pretty well, but I'm wanting to drive the truck to Pigeon forge car show I'm leaving on sept 4th. I still have to install my new aluminum radiator and cooling hoses, make a fan shroud, and do a final tune on it.
Old 08-26-2014, 09:56 PM   #3
Ta2Don
Ta2Don's Avatar
and welcome aboard...
Sounds like you are elbow deep and having a blast…
We really like pics, so don't be shy...
Looks like a good truck and a great start...
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 08-26-2014, 10:09 PM   #4
Ryguy442
I'll post more pics I didn't plan on doing a build page so I didn't take any progress pics of the work iv done, good news is there is plenty more work to be done!
Old 08-26-2014, 10:56 PM   #5
1963c-10
1963c-10's Avatar
Nice score on the stepside. Looks like a solid truck. Im south of you in Fayetteville.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-10-2014, 09:46 PM   #6
Ryguy442
Awesome go thru there on the way to myrtle beach all the time!
I'm not doing well at keeping up with this build page! Been crazy busy tring to get this truck ready for the trip to tennesse. I'm very proud to say, it made it there and back without a single issue. Ran like a champ.
Man I need to lower the front of that thing.
Old 09-10-2014, 11:59 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
Its funny...in the above picture it looks as if you rear cab support are literally GONE or something is really outta wack....Unless my eyes are bad...which they are....I think yer suspensions fine, but yer cab an front clip are mounted wrong or something other.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-11-2014, 07:19 AM   #8
Ryguy442
Your eyes arnt bad, the po got something off when mounting the cab...or the bed. The can mounts are still solid and there seems to be new body bushings... I'm going to jack up the rear of the cab an inch or two and see if it makes it better. That pic for some reason makes it look a lot worse then it is. The hood hinge on the drivers side is back makin the hood sit high and I think it makes the "sag" look worse
Old 09-11-2014, 12:36 PM   #9
61K10
61K10's Avatar
nice truck. just ck all 4 cab mounts and brackets. the rear of the cab should be close to even with the bed step. have you adj the hood hing? does it stay up by it's self? I had to get new springs for mine. keep posting what you find.-----have fun
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-11-2014, 08:36 PM   #10
Ryguy442
Well the story behind the hood hinge was after the truck was painted on the way back from the paint shop the hood popped up I think it bent the hinge. The latch does need some adjustment but can't do that till the hood sits properly. I have a lot of cosmetic stuff to do on the truck now that it's doing well mechanically.
Ryan
Old 09-12-2014, 08:20 AM   #11
1963c-10
1963c-10's Avatar
I may have an extra hinge....let me check the stash this weekend. Which side is it that you need?
Old 09-12-2014, 08:43 AM   #12
Ryguy442
That would be awesome! I need the drivers side. Thanks
Old 09-12-2014, 10:22 AM   #13
1963c-10
1963c-10's Avatar
I'll look this weekend for you.
Old 09-13-2014, 10:09 PM   #14
Ryguy442
We'll think I got some of the sag out of it it's looking better
Old 09-16-2014, 12:36 PM   #15
61K10
61K10's Avatar
looks good now, what did you have to do?
1961 chevy K10
Old 09-16-2014, 02:34 PM   #16
1963c-10
1963c-10's Avatar
Also....found a hood hinge. PM me and we can work out the details.
Old 09-17-2014, 06:56 AM   #17
Ryguy442
I had to bring the back of the cab up about and inch and add to the bushing alittle. Still have to mess with the bed some too to get it right.
Old 09-17-2014, 08:01 AM   #18
TwoFiftyShifter
Your fender is 2-3" off. Mounted too far forward.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 10-14-2014, 10:14 PM   #19
Ryguy442
Sorry no real updates on the truck latly, been a lot going on with work but seem to be working out now..... Last weekend did manage to get my other project loaded up and back home. Also got my buddy's cab to the shop for media blasting, primer and finish up some metalwork. Hopefully I can save up some money for a 3-5 drop kit for the truck sometime soon.
Old 12-09-2014, 04:21 PM   #20
Ryguy442
Well sorry for the lack of updates, had some crap go on at the shop I work at. Now I have a new boss and had to move the shop. That was pretty much 10 days of hell... Here's a few pics we had two blasting booths and a spray booth to take down and move.
Here's a day or two into the move
And the other room
Old 12-09-2014, 04:34 PM   #21
Ryguy442
And here it is now
The side room
This move of course was a bigger under taking then we thought, but it's finally done and over with. I did find some tail light I plan on using on the truck and get rid of this cheap ass trailer lights. Well the shop has moved just north of Hillsboro nc, we should be back up and running in a few months of any of you local guys need some work done just let me know we also do custom body/metal work and paint.
Ryan
Old 12-10-2014, 09:48 AM   #22
Lokin4AReason
Lokin4AReason's Avatar
i see that you been bored, i mean busy lately =0)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 12-10-2014, 12:15 PM   #23
TJ's Chevy
TJ's Chevy's Avatar
wow! What a change. Hope all goes well.
Old 12-10-2014, 03:37 PM   #24
Ryguy442
Yeah I hope so too! Luckly the new owner is someone Iv known for a long time and he does some awesome paint jobs. We met a few years ago in an airbrushing class I used to take. The down side for me is the commute is going to be 35-40 mins and I won't be able to drive the c10 everyday without my paycheck going to gas. But gives me time to fix a few things on it anyways.
Ryan
Old 12-12-2014, 10:14 AM   #25
Ryguy442
Got some time to fix one of the biggest eyesores on the truck, the tailgate. When I bought the truck the center of the tailgate was hacked out. The PO said the tailgate was all beat to hell so he cut it out and had a piece of plexie glass in there, not my style.
Here Iv cut the center panel the rest of the way out and drill the spot welds
Here's the new panel being fit into place
Here it is all welded up. My tig welder is out of order right now so I mig welded it.
I put it back on the truck to see how it will look... It's a bit boring I wish I did something this the bead roller or something but it looks a lot better, still have alittle grinding to do and the prime it
Ryan
