Old 08-26-2014, 09:14 PM   #1
SeTx67
SeTx67's Avatar
Suspension help please
My truck currently has a 4.5"/5" but it seems low in the front after looking at other pics in the static drop thread. Front tires are 255/50r17 and the rears are 275/50r17. With a ls2 I have approximately 1" of clearance front the top of the front tire to the inner fender on the outside edge. Here's a few pics so hopefully you guys can tell me if it looks right or is it lower than I planned for
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline   Reply With Quote
Old 08-26-2014, 09:25 PM   #2
SeTx67
SeTx67's Avatar
Re: Suspension help please
Passenger side
Driver side
Measurement at passenger a arms
Old 08-26-2014, 10:34 PM   #3
bdiamond
Looks good.... If anything, I'd say lower the rear more.
bdiamond is offline   Reply With Quote
Old 08-26-2014, 10:38 PM   #4
JonnyC10
X2.
JonnyC10 is offline   Reply With Quote
Old 08-26-2014, 10:58 PM   #5
SeTx67
SeTx67's Avatar
Don't get me wrong I like it this low but the front tires will already rub and when I go to the new tire and wheel combo I'll lose even more clearance. The current tires are roughly 27" in the front and the new ones will be roughly 28.5". I do have some 1" blocks for the rear but haven't installed them yet. Thanks for the compliments.
Does the current drop look to be on par with a 4.5" drop in y'all's opinion?
Old 08-26-2014, 11:00 PM   #6
Mikeeal33
Mikeeal33's Avatar
No, not to me it doesn't. Looks more like 5.5".
My truck is 5.5"-6" in front, on 16's. Looks more like that. Check it out in my build, I don't want to plaster a pic of my truck on your thread.
1972 Driver SOLD
Mikeeal33 is offline   Reply With Quote
Old 08-26-2014, 11:12 PM   #7
SeTx67
SeTx67's Avatar
Thanks for the help
Plaster away. This is a thread to find out if my truck looks right before ordering new springs for the front. Other pics for comparison with drop and tire info would be helpful
Old 08-26-2014, 11:50 PM   #8
Mikeeal33
Mikeeal33's Avatar
This is 5.5"-6" and my tire is 27" as well. If anything your's looks lower:
I will take the same measurements you did tomorrow so we can compare.
1972 Driver SOLD
Old 08-26-2014, 11:57 PM   #9
SeTx67
SeTx67's Avatar
Sounds good and thank you. Mine does look lower for sure. I'll see if I can find a better side profile shot
Old 08-26-2014, 11:59 PM   #10
SeTx67
SeTx67's Avatar
This is about the best side profile shot I have of the current set up. It has mcgauphys 2.5" spindles and springs up front
Old 08-27-2014, 12:00 AM   #11
Mikeeal33
Mikeeal33's Avatar
My stock LCA's spring cup (lowest point) is about 3" from the ground what about yours?
1972 Driver SOLD
Old 08-27-2014, 12:03 AM   #12
SeTx67
SeTx67's Avatar
I'm out of town for a few weeks and can't get measurements but a low profile jack barely fits under the engine crossmember
Old 08-27-2014, 12:06 AM   #13
Mikeeal33
Mikeeal33's Avatar
I'd put my money on the 2.5" spindle, and 3" springs.
1972 Driver SOLD
Old 08-27-2014, 12:15 AM   #14
SeTx67
SeTx67's Avatar
According to the part number the springs are 2". We've checked, double checked and triple checked lol. The part number is mcgauphys 6082-2
Old 08-27-2014, 12:16 AM   #15
Mikeeal33
Mikeeal33's Avatar
Damn that's why I stay out of the casinos!
1972 Driver SOLD
Old 08-27-2014, 08:28 AM   #16
PGSigns
PGSigns's Avatar
Springs are funny things. 2" in one truck can be 3 or more in another truck. All comes down to spring rate and the front weight. With the LS and the auto, AC power steering and power brakes we all ad to these trucks a spring with a drop based on factory weight will have more drop than advertised.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-27-2014, 11:02 AM   #17
Mikeeal33
Mikeeal33's Avatar
I agree Jimmy. My truck has a 307 with no AC and a manual tranny.
Here's a pic of my driver side:
And the passenger side:
Hope this helps.
1972 Driver SOLD
Old 08-27-2014, 12:44 PM   #18
PGSigns
PGSigns's Avatar
I think the spring rates vary from place to place also.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 08-27-2014, 01:25 PM   #19
Mikeeal33
Mikeeal33's Avatar
Also fwiw, my setup is not a good way to judge, considering I cut stock springs, so the only way to judge is by what is the common rule from what I've seen, 1 coil = 2". It would be much better to judge with aftermarket lowering springs, but like PGSigns said, SO many other factors are in play as well.
Your truck looks low though, and nice. Good luck dude.
1972 Driver SOLD
