![]() Join Date: Sep 2013
Window setting tape
What size is the best for door window to door track on our trucks?
Re: Window setting tape
If you are a purist then visit ur local glass installer. If that isn't so important to you Black gasket type RTV will work fine. After some cleaning of dirt and old material. Allow adequate time to cure n use a razor blade to remove the excess. Light tapping with a 2X4 block or soft mallet to fully seat the U shaped strip channel to the window.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
