Old 08-26-2014, 10:29 PM   #1
Mv7fd
tachometer
I'm thinking about getting a factory tach and putting it in where the fuel gauge is now and getting the smaller factory fuel gauge and putting that where my non working clock is. is this worth doing or would it be easier and better to just get an aftermarket tach and if so where is a good place to put the after market tach
Mv7fd is offline   Reply With Quote
Old 08-26-2014, 10:32 PM   #2
mrolds88
Re: tachometer
I would look for an assembly. If for no other reason that the printed circuit is different. The last square I had, had a Sun tach on the column in between the speedo and fuel guage.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 08-26-2014, 11:07 PM   #3
hatzie
Moderator
hatzie's Avatar
Re: tachometer
Get a complete unit.
73-75 Ammeter mechanical oil pressure Don't use on other years unless you like electrical fires. The 73-75 tachs are less than reliable and potted so the boards can't be repaired just replaced.
76 Volt meter and mechanical oil pressure
77-80 Volt Meter and Electric oil pressure. 100mph speedo dropped to 85mph sometime in this range.
81-89 larger tan font different color needles and mechanical speedo maybe 81-90?
90-91 electric speedo... Maybe only 1991?
Sometime in the 88-91 R/V squares there was a mechanical speedo with trip odometer.
The medium duty 40-60 trucks have tachs with fuel gauges on the bottom so you could put a clock in the lower left corner hole.
Be sure to get a V8 or I6/V6 tach whichever you have... and be sure to avoid the MD diesel tachs.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 08-26-2014, 11:54 PM   #4
86wrangler
Re: tachometer
Someone read my mind yesterday, WOW! Was just strolling through the aisle looking at tachs and was gonna ask the same thing, Id like to leave my 77 as factory looking as i can as its sierra classic. (no sun tach) updated pics please
86wrangler is offline   Reply With Quote
Old 08-27-2014, 03:38 AM   #5
rich weyand
rich weyand's Avatar
Re: tachometer
This is what I did.
http://forum.73-87chevytrucks.com/sm...8352#msg238352
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 08-27-2014, 02:44 PM   #6
johnwaynejeep
Re: tachometer
Hatzie,
I'm putting a dash cluster in my 74 that I sourced from a mid 80s. I wanted to ask you about the dash fire issue you mentioned. I sent you a PM so I'm not hijacking this post. thank you Sir
Robert
1975 C10 - Huckleberry
2007 Jeep JK - John Wayne Jeep
Smittybilt front/rear bumper, 10K winch
Pacific Grove, CA
johnwaynejeep is offline   Reply With Quote
Old 08-27-2014, 02:57 PM   #7
johnwaynejeep
Re: tachometer
Mv7fd,
I noticed that GM had a tendancy to cut holes in the backplane printed circuit board for items that were not used. For instance, my 74 does not have any gauge in the lower left hole, so the backplane is factory cut and there's no way to install anything in that position using the factory backplane wiring. If you want to put in a tach I would suggest sourcing a new instrument cluster with the proper gauges in it already from the junkyard. At least this way all the bits and pieces are there and you can order parts as needed to refurbish the cluster yourself. If you can find the same year cluster with everything in it then it should drop right in with minimal wiring changes to make all the factory gauges work.
by the way, the factory tach in the mid 80s had an independent 3-wire harness going from the cluster to the ground/12v/distributor and it also had an inline resistor in the engine bay for the distributor wire. So, there is no wiring in the factory cluster plug for the tach, it's all independent. You can run your own wires because they are all just blade style plugs, but you'll have to find the resistor and put that in line, this is another reason to pull a factory cluster from the same model year becuase you can get the factory harness and resistor for the tach. Look up Hatzie's post that contains wiring diagrams, it should help
Robert
Pacific Grove, CA
Old 08-27-2014, 03:05 PM   #8
Just call me Sean
Just call me Sean's Avatar
Re: tachometer
The lower left hole is where the clock goes. It has its own separate plug.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
