Old 08-27-2014, 11:44 AM   #1
maschka
Cummins In 72 Suspension Question
I have a 72 3/4 ton 4x4 that i am considering throwing a 4BT into. Ever swap I have seen looks to have a 4"ish suspension lift. I this pretty much mandatory? I would like to stay closer to the stock height. Thanks for the help.
maschka is offline   Reply With Quote
Old 08-27-2014, 07:15 PM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Cummins In 72 Suspension Question
With stock height, the oil pan is going to be sitting on your front diff, or pretty darn close. The drive shaft will be all in the way too. A 2.5" lift might get it but the oil pan will still be way close.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 08-27-2014, 07:56 PM   #3
ryanroo
ryanroo's Avatar
well, i know of a truck that clears at lower than stock height... haha
but yes, a lift is generally required. if you want to push the engine back a ways it helps you get it lower, but as ryan said, with the GM front diff, the driveline is close. oil pan can be modified to help with that, but it is easier to lift it a touch. lifted 4 inches and these trucks are still comparable to todays OEM trucks in height.
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 11-08-2014, 11:00 PM   #4
Nott32
Sorry to thread steal,does the 2wd need a lift? I have a 70 but just bought complete front crossmember with disc brakes from a 73
Nott32 is offline   Reply With Quote
Old 11-10-2014, 03:10 PM   #5
Dieselwrencher
No, a 2wd will be fine. There's plenty of room for the cross member. The rear sump of the oil pan may be close to the ground if you plan to lower it though.
Ryan
Old 11-10-2014, 07:41 PM   #6
rgreathouse
I have a 72 4x4 with a 6bt. Where my engine is sitting about the lowest I was able to get is a 4" lift using custom leafs from ORD. I wish I could have gone lower but it wouldn't be very usable because of oil pan to front diff clearance.
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 11-13-2014, 04:14 AM   #7
muffintop
this sucks. so how about wheeling? if i hit a big enough bump will the diff be pushed into the oil pan???
muffintop is offline   Reply With Quote
Old 11-13-2014, 10:05 PM   #8
Dieselwrencher
Yes it can be.
Ryan
