70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Spid RPO Question
This truck is For Sale on Ebay now and it has an option on the Spid I've never seen and don't know what it is. The option is the K71 HD Valve and Rotator. Can someone explain.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Re: Spid RPO Question
Link? Unless you're worried someone is going to poach it out from under you, you haven't provided a lot of info here....
I don't even know what the CM vin prefix is. Diesel?
member #16
![]() Join Date: Dec 1999
M is for the v/6 engine, probably a 305 with no engine options listed. I believe you could order with exhaust valve rotators.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
If the engine still has them, which I assume it does, you should be able to tell that the exhaust valve retainer is a lot thicker than the intake. It's some kind of mechanism that, as you might guess, rotates the valve, extending its life.
Exhaust valves take more abuse than intake valves, so I guess they only offered them on the exhaust. Weird it's an option and not just a feature.
#5 | |
member #16
#6 | |
http://www.ebay.com/itm/231315471130...84.m1423.l2649
