Old 08-27-2014, 03:22 PM   #1
G-NUT
G-NUT's Avatar
anyone with pics of a square on 24's and porterbuilt suspension at ride height
Anyone on here have an pics of their square body using a Porterbuilt Front / Rear dropmember setup and running 24" wheels, front & rear or rear only, either one?
More specifically at ride height?
Thanks,
G
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline   Reply With Quote
Old 09-02-2014, 11:00 AM   #2
G-NUT
G-NUT's Avatar
Re: anyone with pics of a square on 24's and porterbuilt suspension at ride height
bump
Old 10-14-2014, 04:24 PM   #3
G-NUT
G-NUT's Avatar
bump
Old 10-14-2014, 05:56 PM   #4
SCOTI
SCOTI's Avatar
I know of @ least 1 member that had >22's but I can't recall his screen name. His truck was @ SEMA multiple years though....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-15-2014, 09:09 AM   #5
2120
2120's Avatar
http://youtu.be/zGsg4TSw5_U Try searching the Reyna bros c10 I believe they have two c10's lowered with 24" rims in the rear and 22" in the front.
2120 is offline   Reply With Quote
Old 10-15-2014, 09:19 AM   #6
paul66c10
paul66c10's Avatar
Thanks,
G
I have full porterbuilt suspension, not done yet but i have a pic of it at full lift and aired out. If that helps you any. 24x10 centerline smoothies all around on 275/25r24. Changing tire sizes soon.
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy
paul66c10 is offline   Reply With Quote
Old 10-15-2014, 09:50 AM   #7
G-NUT
G-NUT's Avatar
Thanks guys. I ask cause I already bought the complete Porterbuilt Level 3 front dropmember & McGaughy 2.5" drop spindles for the front, gonna convert to 5 lug. As for the rear setup, I may go with Porterbuilt or maybe the KP components (Chassisworks) rear setup. I've seen tons of pics of squares on 22, 24, 22/24 with the Porterbuilt components but not really seen any at ride height on these wheels. I've been trying to decide on the wheel setup I wanted to with; 22, 24, or 22/24. Since I'm going with the long bed, I kinda thought the 24's in the rear would stand out.
Old 10-15-2014, 10:12 AM   #8
G-NUT
G-NUT's Avatar
Old 10-15-2014, 10:25 AM   #9
Blown06
Blown06's Avatar
My buddy has been doing a bunch of 67-72 drops lately for Rhea's Chevy's. You can checkout pics of some of the builds on his instagram at chassisfabjohn. Unfortunately not many are with Dropmembers it may give you an idea of the look on 24's.
*Sorry, just noticed what year you were after.
Blown06 is offline   Reply With Quote
Old 10-15-2014, 11:04 AM   #10
G-NUT
G-NUT's Avatar
Thanks Blown06. I appreciate it. I do have a rheaschevs instagram bookmarked. I'll check it out your budds to though.
Sorry , forgot the info. The pic 2 posts back is what I'm starting with. Got it from the 2nd owner who's had is since '94. He towed a 5th wheel camper with it all the time. He is a rattlesnake wrangler, FOR REAL, and has been for years. My wife made me check the truck thoroughly before she'd ride in it.
Old 10-29-2014, 02:01 PM   #11
G-NUT
G-NUT's Avatar
bump
Old 10-30-2014, 11:40 PM   #12
slimneverdies
slimneverdies's Avatar
Off topic a little. You have a level 3 front dropmember for a C20? If it's 8 lug than I'm a little confused. I'm about to buy another dropmember and was told that the c20/c30 would only need the level 2 because of the height difference of the frame bump...
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 10-31-2014, 10:23 AM   #13
G-NUT
G-NUT's Avatar
Mine is 8-lug but I've going to convert it to 5-lug by swapping the rear end and the front rotors. I have c10 spindles, ball joints, and Porterbuilt upper and lower control arms. I ordered mine through one of Porterbuilt's authorized vendors. I specified in great detail the truck I had, and what I was planning on doing and that's what I was sent. Best I can remember though, I had contacted Porterbuilt about a year ago on this topic and I think that's what they told me was that a Level 2 would be sufficient because of how the frame hangs lower below the body of the C20/30 than a 10. But I am going to cut the frame even with the pinchweld of the truck and weld in some 2x3 steel tubing inside the frame so I believe the level 3 will be necessary to achieve getting the pinchweld to the ground.
I have not installed mine yet as I only have the front. I'm saving right now to get the rear. Then I will have to save again to get my air management system. I probably won't have mine on for another year and a half or better, which stinks.
Old 11-01-2014, 01:55 PM   #14
tobytuttle
tobytuttle's Avatar
well here is one of my old "square'' body burb's,, definitley ride/stock height, no porter but 24'' wheels
70 SS 454 Monte
69 355 C-10 Shortbed
90 454 Crew dually 4x
76 454 Dually 2x
75 454 K5
77 468 Kona
tobytuttle is offline   Reply With Quote
