08-27-2014, 06:53 PM | #1 |
6.0 swap Gas Tank
I'm doing a 6.0 engine/trans swap (2007 Silverado-donor) to my 1970 Suburban. I have the gas tank out of the 2007 pickup but It won't fit my '70. What have you guys done for a gas tank? I don't mind getting an aftermarket tank and pump but have searched the net with no luck so far. Any ideas? Thanks
08-27-2014, 11:01 PM | #2 |
Re: 6.0 swap Gas Tank
im putting in a LS3 and have a billet fuel cell. several suppliers make a intank pump for the ls motors for certain fuel cell tops/bolt pattern/depth.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's 1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's 1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's |
08-28-2014, 01:20 AM | #3 |
Collector of Projects
http://vaporworx.com I used the RetroWorx kit and installed a factory 2005 truck fuel pump module into my tank. Now I built a custom tank, but you should be able to add this to a factory tank. They use a Cadillac fuel pump but the tuck one is taller. Check out the build thread in my signature for a few pictures...
PS: there is a specific section for all LSx swap questions.. more info in there ... http://67-72chevytrucks.com/vboard/f...play.php?f=206 Last edited by mcmlxix; 08-28-2014 at 01:25 AM. Reason: added link |
09-18-2014, 11:11 AM | #4 |
C10 Club Tennessee
I used a tank out of an 87 G10 Van. Got it off Ebay for $82 shipped. Used the original sending unit, but swapped out the pump for an EP381 AC Delco. The pump fits right in there, the tank needed a little bit of trimming. and I grabbed the brackets from a junkyard one.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
09-18-2014, 12:33 PM | #5 |
Half a page down is a thread on using R/V body fuel tanks
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
09-19-2014, 02:13 PM | #6 |
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks... |
