Old 08-27-2014, 07:44 PM   #1
Cheyyenne81
Rear axle swap??
Having a hard time trying to figure out what type of rear end to go with.... The truck will be used for racing everyone says a ford 9 inch. Good choice? I have thought of doing a rear disk conversion on my current axle just don't know if the axle will hold up to a built 350 motor. NEED ADVICE!!
Cheyyenne81 is offline   Reply With Quote
Old 08-27-2014, 07:58 PM   #2
Just call me Sean
Just call me Sean's Avatar
Re: Rear axle swap??
What axle do you have now?
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 08-27-2014, 10:06 PM   #3
Keith Seymore
Keith Seymore's Avatar
I've been running the original 8.5" ring gear 10 bolt rear axle in my Chevelle for 36 years. Mark Williams spool, axles and C clip eliminators. Welded tubes.
Current best is 9.85 @ 136 mph; approx 900 HP naturally aspirated at 3900 lbs.
You'll be fine.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
#axleswap #racing
