08-27-2014, 08:45 PM | #1 |
Chrome gear shifter is all I see...
'57 Panel, probably a Chevy van tilt wheel column.
Fairly often, smack dab in front of my vision, is the reflection of the chrome gear selector arm. What have you done to cure this? Suggestions? "Only drive on cloudy days" ??
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
08-27-2014, 08:57 PM | #2 |
Re: Chrome gear shifter is all I see...
Scotch Brite pad to make it a satin look? You could always paint it with plasti-dip.... you could peel it off if you don't like it. You could take it off and put a floor shifter in.
Just because you can, doesn't necessarily mean you should. 1959 3100 stepside 355 + T5 |
08-27-2014, 09:48 PM | #3 |
Drive the roll pin out and pull the handle. Refinish it as sugested or look at Lokar Midnight series shifters.
GOD BLESS AMERICA! |
08-27-2014, 10:01 PM | #4 |
Good suggestions, guys.
I forgot about "pulling the pin". I was thinking of masking tape, newspaper and a rattle can of flat black. None of which sounded very good. No floor shift, though. I like my roomy, flat floor space, especially after driving my wife's Accord coupe last weekend.
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck Last edited by Highsider; 08-27-2014 at 10:15 PM. |
08-27-2014, 10:42 PM | #5 |
Be cheap - wrap the shifter with black electrical tape
08-28-2014, 08:23 AM | #6 |
Oh, you KNOW that was my first thought!
08-28-2014, 10:58 AM | #7 |
All jokes aside that would let you know if painting the shift handle or dulling the finish would accomplish what you want or you end up seeing the reflection of the taped up handle in the windshield.
08-28-2014, 12:15 PM | #8 |
After you take the pin out and remove the shift handle run to a wrecking yard and find a smaller arm different shape or angle GM made a bunch of different handles front wheel & rear wheel drive cars. GM's are basically the same at the point where the pin goes in... Don't forget to take the old one to compare! I have a GM Van Tilt and found that a Chevy cavalier handle worked great. I ground down the plastic handle and fitted an after market billet aluminum end to it you can also maybe throw a beer tap handle at the end or skull what ever to the end.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
08-28-2014, 12:26 PM | #9 |
How about heat shrink tubing, various colors available if black does'nt take your fancy.
08-28-2014, 01:10 PM | #10 |
Or wire loom for the carbon fiber look... I used this for my wiring in 1/4 and 1/2 inch side
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
08-28-2014, 02:21 PM | #11 |
nverdone and mr48 convinced me to "experiment" with black electrical tape.
If it doesn't give me a clue as to what may work, peeling it off will be easy. Thanks, folks!
