Old 08-27-2014, 10:58 PM   #1
Dcm
Power steering compatibility
From what I've found, the original steering linkage that connects the pwr steering pump to the steering column is a component that is no longer available. Updated units are available. But I'm wondering if I can't visit the local salvage yard and get a linkage from a newer chevy truck? Maybe even pwr steering pump and all?
Dcm is offline   Reply With Quote
Old 08-27-2014, 11:00 PM   #2
Dcm
Re: Power steering compatibility
May help if I included what the heck kinda truck I have. (Yep, I'm a bonehead). 70 swb 1/2 ton. 350 with 350 auto.
Old 08-27-2014, 11:36 PM   #3
69chevytrucker
69chevytrucker's Avatar
i have a 69 with a steering column fr om a 85 steering box and all there is some modifying that needs to be done to the column but not too hard if you handy
just need to knock off all the welded nuts of the 85 column and trim the collar below the shifter to clear the dash cut off like 3 or 4 inches of it cut the plug off for the wires splice your old plug on easyer then it sounds colors of the wires are the same the plug end are just different bolt it up and you have what i have above
69chevytrucker is offline   Reply With Quote
Old 08-28-2014, 08:05 AM   #4
Dcm
@69chevytrucker...
�� you sir are awesome!
Old 08-28-2014, 08:49 PM   #5
69chevytrucker
Originally Posted by Dcm View Post
@69chevytrucker...
lol i just dont take wont fit for a answer if you got the right tools you can make it fit lol
