Old 08-10-2003, 12:08 AM   #1
love it loud
Calibration Engineer
love it loud's Avatar
lower balljoints
Went to put new lower balljoints into the lower control arms of my 80.. and whoops! they drop right in easily! Is there any way to make the hole smaller or would it be ok to maybe weld the balljoint in place? I'm thinkin 3 or 4 tack welds should hold it in place pretty good and not heat it up enough to do any damage inside.. Please offer any input as I have many hours into these lca's removing the old bushings and installing polyurethane ones, as well and sandblasting and painting.. there's gotta be a way to save em! Must be some trick to holdin that lower balljoint in as I've heard other people have had the same problem but just ignored it..
CANADIAN CONNECTION
love it loud is offline   Reply With Quote
Old 08-10-2003, 07:28 PM   #2
love it loud
nevermind, figured out a solution
CANADIAN CONNECTION
Old 08-10-2003, 09:40 PM   #3
rin68
rin68's Avatar
i think there are oversize ball joints made for precisely your problem.....
1968 C10 - 383, non-stop project
1969 Camaro - 327, bone stock family heirloom...soon to be LS/T56, Ridetech, all the goodies
rin68 is offline   Reply With Quote
Old 08-10-2003, 09:45 PM   #4
love it loud
just shrink the hole
CANADIAN CONNECTION
Old 08-14-2003, 02:13 PM   #5
Linus0014
Guest
Posts: n/a
"Just shrink the hole", how do you do that?
Old 08-14-2003, 10:00 PM   #6
love it loud
smoke wrench and a BFH
CANADIAN CONNECTION
Old 08-15-2003, 11:05 PM   #7
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Remind me not to ride in your truck!!! Good Luck!!
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 08-16-2003, 12:14 AM   #8
love it loud
umm.. why not?
CANADIAN CONNECTION
Old 08-16-2003, 12:43 AM   #9
crazy longhorn
Fabricate till you "puke"
I think I would opt for oversized ball joints, rather than "play" with the arms. I have tack welded ball joints in an old truck, that didnt have a tight press(not the best way to go, & I wouldnt reccomend it on something you plan to drive for a long time). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-16-2003, 01:04 PM   #10
phantom dually
Its not worth it MAN!!
Old 09-02-2003, 11:28 PM   #11
pa_snowman
some times the good ole "adjustable heat wrench" and a little freindly persuation is the best way to go but not when your wheels might fall off.
jim gallagher
pa_snowman is offline   Reply With Quote
Old 12-24-2005, 04:50 PM   #12
pa_snowman
Re: lower balljoints
do you have the p/n for those oversize ball joints? if so please post it for everyone that may need them.
jim gallagher
Old 12-24-2005, 06:37 PM   #13
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
They're under tension. The front springs tends to pull them into place. They can't fall out. Tack weld them in place. I've done it in the past.
