Old 08-28-2014, 11:04 AM   #1
taylorbg
Axle Swap
I came across a 1991 3/4 ton 4x4 Suburban with 4:56 gears. I have a 1972 4x4 Suburban 350/350 with 33 inch tires. The main purpose of my Burb is to tow my boat, which right now is struggling, especially on any hill.
My question is, if I wanted those gears will the 91 axles swap in? Are those gears too low for 33 inch tires, or should I be looking for closer to 4.10? It also has a 4180 trans. Would that be better for towing than the current 350?
taylorbg is offline   Reply With Quote
Old 08-28-2014, 11:47 AM   #2
04sshd
04sshd's Avatar
Re: Axle Swap
3.73 or 4.10 would be ideal for 33" tires. 3.73 is a good gear ratio for the 350 trans, if you go 4.10 you will have your towing range but your RPM's will be high on the highway.
If you want to do an axle swap, you might have to re-weld the axle mounts. Aside from that they should go right in. 91 is still solid front axle on the burbs so at least you won't have to mess with the IFS on the newer bodies.
1968 Chevy C-10 Suburban - 350/350
1969 Chevy C-10 Panel Delivery - 454/400
1972 GMC K1500 Jimmy - 350/350/np205
1978 Chevy Corvette Silver 25th Anniversary
reddit.com/r/chevyc10 <-Join it!
04sshd is offline   Reply With Quote
Old 08-28-2014, 12:54 PM   #3
vectorit
What?
vectorit's Avatar
Re: Axle Swap
I currently run 4.57 gear ratio, which is the original ratio for my Suburban.
They are very low, and I run 33" tall tires.
Highway speed is 65, any faster I go into secondaries.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-28-2014, 09:56 PM   #4
Cobalt964ruf
Cobalt964ruf's Avatar
Re: Axle Swap
in my 2001 k2500hd I have oem 4.10's with a 4l80e and run 35's. it pulls very well still, and highway 75mph is 2300rpm's with the overdrive trans. best of all worlds.
post script; now grant it my 2001 does have a 400hp lsx tho too. so pulling really isn't an issue.
1971 K30 burb carbed LS6 th400 np205 d70f 14bff 4whl discs lifted 35 bfg's
1994 k3500 rcsb trophy truck ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1998 K3500 rclb ls427 4l85e bw4401 9.25ifs 14bff g80 35 bfg's
1999 k3500 crewcab dually 4x4 496ci 4l85e bw4401 9.25ifs 14bff g80 6" lift 37 bfg's
Cobalt964ruf is offline   Reply With Quote
Old 09-03-2014, 02:55 PM   #5
taylorbg
Re: Axle Swap
I found a metal tab on one of the bolts on the front axle. It says 373, so I guess at this point I can assume the gears are 3.73? Assuming no one has re geared in the past. These should work in the short term, maybe at a later date go to a 4.10 if I feel the need. Maybe I will look at other things to change so it is not a major dog pulling that boat, especially up the smallest hill.
