08-28-2014, 11:42 AM | #1 |
Pick n Pulls 50% off sale. whats interchangeable at the yard?
Im going to be at the pick,n pull yard tomorrow and,wanted to know what to,be on the lookout for that would work or be interchangeable for my 68' C10?
08-28-2014, 12:04 PM | #2 |
Re: Pick n Pulls 50% off sale. whats interchangeable at the yard?
Any front end body panels off a 67 and then pretty much everything from the cowl panel back is the same I believe, except 72 door panels. Someone else will have more info, and anyone else feel free to correct me.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
08-28-2014, 12:08 PM | #3 |
I'm not exactly understanding what you are asking. Do you mean amongst other 67-72 chevy's and gmc's, or amongst other year trucks? Explain what you are looking for as that's a much easier way to narrow it down. In order to give you interchangeability we'd have to brake down ALL parts that have differences. To do that, use keyword "differences" or something similar in a search and that would help you determine what would work.
08-28-2014, 12:09 PM | #4 |
While the grill would bolt up to the front fenders of a 67, they have no side marker lights. You also have a parking brake pull handle for 67-68 vs. the pedal in 69-72. Search will be your best friend in this case.
08-28-2014, 12:18 PM | #5 | |
08-28-2014, 12:39 PM | #6 |
Do the Dew!
Just go to the salvage yard and have them bring up the various parts that you're looking for and have them print out the list of what all that they fit on. They have the Hollanders interchange system that is quite frankly really awesome when it comes to product fitment applications.
08-28-2014, 12:44 PM | #7 |
Haha, another c10 from Sac. You must have just heard the ad on the radio too. I was jist listening to 98 and heard the commercial and thought "is there anything I need?"
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding My build : 68 C10 Short Bed Conversion |
08-28-2014, 12:50 PM | #8 |
thats exactly what i was thinking!!! hahhai do need a new seat. im going to try if i can find a truck seat with a console in the middle
08-28-2014, 12:51 PM | #9 |
What do you need?
08-28-2014, 12:57 PM | #10 |
GM parts book is a good place to start as there are many options on procuring parts interchangeability from different years
08-28-2014, 12:58 PM | #11 |
Do you need any steering or frame pieces? I have a 67 parts truck with body cancer but it has all the suspension and drum brakes and I have it on a trailer today to take it to a dismantler. But if you had room for it and are somewhat near to rancho cordova you can have it. Ill deliver it for some gas money.
08-28-2014, 01:03 PM | #12 |
Would that be work as in "bolts right on," or "can be made to fit with the right adapter / Sawzall work / welding"? The latter opens up a LOT more possibilities.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
08-28-2014, 02:29 PM | #13 |
Sisyphus was my mentor!
The 140a cs144 alternator is a sweet & easy bolt in to our v-belt trucks. I know that a 94 caprice 140a alternator bolts in & got two from Northstar-equiped Cadallics that are exactly the same & 140a. There may be others, but those I have personally verified. You need only tweak the bracket a tiny bit & i was able to adjust my fractory bracket by hand. Get the harness plug as well, solder in a resistor & you have a killer alternator.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
08-28-2014, 02:56 PM | #14 |
Just to generalize and cover this broad question- nearly all chassis parts will interchange- steering included. Steering boxes through 88 will bolt up. Rear ends have slight width differences. E brake is different for 68 and 69+. All seats bolt up 67-72. 88+ seats bolt in with minimal work and varying styles. Good luck with buckets and console in this area, and they require bolt holes drilled. Outside mirrors are different 71+. This is a quick and dirty cover, there's exceptions.
08-28-2014, 10:14 PM | #15 |
Front sway bars are interchangeable to 87 on 1/2 and 3/4 ton, 91(?) 0n 1 ton.
08-28-2014, 10:39 PM | #16 | |
08-28-2014, 10:43 PM | #17 |
plus my steering column is from 85 little mod needed
08-28-2014, 10:45 PM | #18 |
Be on the lookout for tilt columns. I found one out of an old motor home that is a direct bolt in for these trucks for little of nothing. And, pretty much all motor homes are low miles, so the columns are usually like new and tight. It took me about 2 hours to get mine out, but I got it for $35, so I didn't care how long it took..... it was worth it.
08-28-2014, 10:52 PM | #19 |
I heard about the Pick-N-Pull sale, too. Thought I'd go looking for 6 lug disc brake steelies but I've never been... do I bring my own tools? Jack too?
08-29-2014, 12:19 AM | #20 |
You need to bring your own tools, but they may not let you in with the jack -- liability issues. At the P&Ps in Kansas City, they use steelies as jack stands so most of the cars are already up in the air.
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
08-29-2014, 12:22 AM | #21 |
Thanks. Just read the fine print... wheels and tires are excluded from the sale.
08-29-2014, 02:21 AM | #22 |
Moderator
Bring your own tools. Jacks are not allowed to be brought in the yard (but if you look around, scissor jacks are plentiful ). There are hoists available for use if you lift anything. Wheel/Rim sales occur way more often than 50% off sales, just watch for them. If you want to save 50% all the time, and you are "resourceful", just pull what you are after and stash it somewhere in the yard where nobody will find it...wait for a 50% off day, then go and retrieve it . Nearly every pick n pull in the country is owned by LKQ, and the rules, prices, and sales are universal.
As far as finding good or desireable parts on a 67-72 truck...good luck, lol. Unless you are the first guy there, waiting and watching when the forklift drops the truck onto the makeshift jack stands, the truck will look like a school of piranhas feasted on it The last "good" part I got was a center console out of a 75 Blazer about 5 years ago...truck was third in the row, had been in the yard maybe 15 mins. I hopped in and as I was removing the first bolt, another cat rolled up and was majorly bummed (putting it mildly) that I was pulling it. There were at least a half dozen other dudes that strolled by for a look while I was in it, and would have surely grabbed it if I was not there.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
08-29-2014, 02:23 AM | #23 |
Collector of Projects
73+ Square body can offer a front swaybar... 3/4 tons have a big front bar
09-08-2014, 12:54 AM | #24 | |
09-08-2014, 01:11 AM | #25 |
