View Poll Results: Do I swap or not
Swap suspension to newer style( with discs) then drop 3 20.00%
Just drop front and upgrade brakes to discs( spindles will allow me to upgrade without problem 12 80.00%
Voters: 15. You may not vote on this poll
Old 08-10-2003, 12:37 AM   #1
GMC69
GMC69's Avatar
Question To swap or not!
Here is the scoop here is the truck
I would like to swap the front suspensioin from this truck
BUT here is my dilema, I can get drop spindles from MotherTruckers
that will allow me to not bother with the suspension swap ( stronger crossmember on my 69), less time spent, and less $$$ to do it, since I am getting drop spindles anyhow, and just upgrade my brakes to the newer style and bolt up to the original balljoints tie rods etc...
So do I swap the suspension and be able to use newer suspension parts on it
OR
keep the old suspension and get the drop spindles and be able to convert to 5 bolt discs,
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline   Reply With Quote
Old 08-10-2003, 06:39 PM   #2
GMC69
GMC69's Avatar
Well just about 40 people have read this post but not one feedback on it.
I am sure people have opinions out there.
Mike
2019 Silvedrado 4x4
Old 08-10-2003, 08:11 PM   #3
Red68
Red68's Avatar
I would keep the 69 setup and upgrade to disk brakes and new front suspension parts. I own a 68 and recently lowered it with new drop spindles, 1" lower springs, disc brakes and new ball joints and tie-rods etc. Easy to do and works great. Just my 2 cents.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 08-10-2003, 08:35 PM   #4
crazy longhorn
Fabricate till you "puke"
When I did my swap, there were no aftermarket parts for the 67-72s. the longhorn has 75 spindles,brakes balljoints, & tierod assys......original top a arms, & 71-72 lower arms(its set up for a 73 up bell tech spindle). Take a look at all the front end pcs on the 69, & if they are in good shape, your best bet would probably be going with the aftermarket dropped spindle to fit the truck....if you have a lot of worn parts, you could go either way & probably not see any diff in price. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-10-2003, 09:26 PM   #5
lunatic
lunatic's Avatar
I ll go with Red68,buy the kit and save yourself some headaches,WOW Snow in Sudbury already?LOL....
lunatic is offline   Reply With Quote
Old 08-10-2003, 10:42 PM   #6
GMC69
GMC69's Avatar
That was taken this winter and since it is the truck I was given to rape parts off of I didn't bother taking more pics of it.
THe parts raping has begun, stole the power steering pump and steering box off of ot today, but ran out of daylight to swap it on my truck so it will have to wait till next weekend or the weekend after that.
Mike
2019 Silvedrado 4x4
