Old 08-28-2014, 03:08 PM   #1
Hugh Mongus
TH350 Kickdown
My kick-down is not working on my new transmission. Should I just tighten the cable a little (adjustable Lokar) or could that cause internal damage? Not sure what action to take to correct the problem. It was set by a local transmission shop previously.
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 08-28-2014, 04:12 PM   #2
70cst
70cst's Avatar
Re: TH350 Kickdown
Bump
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 08-29-2014, 04:33 PM   #3
sKnNyPpY
sKnNyPpY's Avatar
Re: TH350 Kickdown
I have an ATP kick-down cable replacement and the setup is very similar. While the engine is off make sure the cable itself extends/retracts smoothly first, if not it might be binding. Then open up the clip on the bracket and manually open the throttle on the carb all the way. While holding the throttle open release/close the bracket. From what I read the kick-down is far less integral or detrimental in operation than a TV cable for an overdrive tranny. It took me a couple of tries for the "kick-down' to kick! http://www.lokar.com/downloads/pdf-i...acket-Only.pdf
Life is too long to go slow...
71 GMC 1500 Super Custom LWB
350/350 AC(replaced w/vintage air)/PS/PB
2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt
20x8.5 OldSkools 5" BS, 275/45 Falkens
sKnNyPpY is offline   Reply With Quote
Old 08-29-2014, 08:10 PM   #4
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: TH350 Kickdown
The kickdown in the older Turbo Hydramatics is just that... a kickdown to 2nd gear. It will also allow the transmission to downshift and hold it in second like when taking a corner at slower speeds.
You can even disconect it if you want, and it will only affect the 3 back to 2 shift. So if you want passing gear you will have to manually shift it down. The only thing it will do if misadjusted is annoy you as it either downshifts way to early, or way to late, or not at all.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-29-2014, 11:51 PM   #5
litew8
litew8's Avatar
Re: TH350 Kickdown
mine isn't hooked up
project: "my happy mess"
litew8 is offline   Reply With Quote
