I want to talk with the guy at GM that decited this for the Long beds!!
Me too. I used to have a long bed GMC with a 402 BB and a 400 trans. Twice when I let it shift out of first to second by itself, it broke the driveshaft. Two tow bills
1972 Chevy Truck Short Bed 402 BB 1987 Buick Grand National, not stock 1969 Camaro SS 454, definitely not stock, Fogger 1982 S-10 truck 350 1970 GMC Truck Long Bed 402 BB 1997 Camaro Z28 M6 |
Designated A-hole!
HE!! I have a two piece on a short bed!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Old Skool Club
![]() Join Date: Jun 2001
Me Too!!!
Both of the '69's I've had, both SWB, had/have 2-pc drive shafts. I rebuilt my son's, when the center carrier bearing broke loose from the rubber mount in the support. I also had to replace the center support on my '65 LWB.
I don't think you can get a one-piece shaft for the LWB, but money will get you one for the SWB. When they get too long, you have to be careful of "whip", or the flexing of the longer shaft. Shorter shafts don't have that problem. How long can a drive shaft be, and not have the "whip" problem? I don't know. Anyone know? Just be happy that you don't have to pay for a new drive shaft on a C-5 'Vette. Ask anyone who has, and you'll be happy with your problem.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
its all about the +6 inches
6 foot is the rule of thumb on drive shafts. That is one reason the engine sits so far back in the 73 - 87, and also why they get longh shaft trannys.
You can get shafts over 6 foot long, but it does cost you a pretty penny. If you were to replace everthing on your driveshaft...all new U-joints and C-bearing, and get the best stuff you can find, it will hold up to almost anything you can feed it. I personally knew a guy who was running high 12's in a 67 lwb and never had a problem. This was also his only vehicle, so it was the daily driver too. It can be done...I just wish I woulda asked about teh brands he used before I left Tx. ![]() |
Old member
2 peice drive shafts
I had mine built about 150,000 miles ago with greasable fittings. New center bearing and I had it balanced, and never had anymore trouble with it.
I will also say it isn't a torque monster either, just a 305 HO TPI out of a 86 camero. It too is my everyday driver between SC., and NC. . I have the 700R-4 in it and it normal running speed is around 65-75 mph. ![]() ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
i guess mines pretty smart cause it's gone over 100K miles since i've had it balanced and u-joints and carrier bearing put on. i think in a case of you get out of it what you put into it
I have a 69 GMC with a 396 and a 400 tranny. I've never had any problem with the drive line except the carrier bearing housing brackets that connect to the frame broke off. Welded them back together and haven't had a problem. I drive my truck hard. Lots of burnoffs and hard shifts.
One other thing, the U-joints that are sealed for life are a little stronger than the ones with zerk fittings.
Some seem afraid of them not lasting as long, but I had 2 of them on my wife's '92 S-10 Blazer, they were stock and after 140,000 miles, they were still in perfect shape. They went to the junk yard along with the rest of the POS. Oh, lack of fittings means we can be lazy. ![]() |
18436572
I just bought a 70' shortbed 2wd and can i just get an onepiece driveshaft made?
If i do, it will be an aluminum shaft. |
WHEW you scared me there I thought I had a short bed with one of those ultra rare option 2 piece drive shafts LOL.
I cant answer your question but i am following to since Im not sure I want to keep the original
2008 Buick Enclave(wifes new non wrecked) 1996 Jeep Cherokee 2002 2500HD 6.0L (traded) 1998 Jeep Grand Cherokee(wifes/wrecked) 1977 DJ5 postal jeep(mmm lots of fun) 1988 Toyota 2wd p/u(DD, blewup 199,000) 1991 Toyota 2ed p/u (sry just cant break these things) 1997 XR70 Honda 1991 Z50(FOR SALE) 1972 Z50 Honda 1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end". |
Got a 71 SB with 2 piece behind a 502 with no problems. (yet)
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
#13 |
I have never had problems with the 2 piece shafts but have had problems with center carrier bearings. I went to drive shafts unlimited in Arnold, Mo and they said for a one piece shaft the bottom of the crossmember where the carrier bearing is would have to be cut off. the trailing arms are attached to it also so there would be a strength issue most likely.
1969 Chevy C10. Dakota Digital Gauges, 383 Votex Engine, MSD 8361 Distributor, MSD 6A Unit, Demon Carb, Phoenix Transmission 4L80E trans, 3:73 Posi Rear End Early Classics 6 Lug Disc Brakes and Spindles All Stainless Lines |
#14 |
I looked into getting a 1 piece driveshaft when I dropped a driveshaft cause the U-joint broke.
The guy at the driveshaft place said it could be done, but I'd run into problems with "whip" over 90 mph and that was with a 4 or 4 1/2" diameter driveshaft (require modification to that crossmember. I just had them build me a new DS |
#15 |
As for the short bed question, my 69 GMC SWB has a single shaft, with a short shaft TH350 bolted to a small block and with a coil rear suspention...it somes in at exactly 4 foot 10 inches.
#16 |
![]() Join Date: Oct 2001
That 72 swb truck that I'm work with had a 6cyl with a 3 speed and I one piece drive shaft and when I put the BB and 400 turbo in the correct postion I had to change the drive shaft out because the other one was a little short,anyway I went down to the Truck Shack and looked through my drive shafts and noticed one that was alittle longer then the other 1 piece drive shafts well anyway I brought it home and sized it up with the big 400 yoke and it fit perfect! If anyone needs a 2 piece drive shaft for a BB truck I got one minus the 400 yoke!
Things happen for a reason! |
#17 |
i have a 1 pice drive shaft on a 71 3 on the tree lwb it was a bout 400$ but i could not kept a 2 pice it would break off every time i put a new one in so i found a guy in Az that built one and it was worth the money i have had no probs since i got it
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
#18 |
Denny
If you've had problems with the center carrier bearing, then you have had trouble with the drive shaft.......it's the whole design that makes it bad.
