Old 08-28-2014, 05:18 PM   #1
eugrides
ifs crossmember
Installing an ifs crossmember on my 53 /2 ton longbed . I have truck sitting at stance I want and frame rails level with each other. I am going to level crossmember side to side like frame rails . Do I need to level crossmember front to back or just weld to frame. IFS is from Speedway
eugrides is offline   Reply With Quote
Old 08-28-2014, 10:50 PM   #2
Guilty By Design
Guilty By Design's Avatar
Re: ifs crossmember
It should be level as not to screw with the caster angle set from the manufacturer.
Guilty By Design is offline   Reply With Quote
Old 08-28-2014, 10:55 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: ifs crossmember
Yes, level in relation to the ground regardless of whatever rake your frame is set at. Did your IFS have any instructions?
--Josh
Old 08-29-2014, 07:51 AM   #4
eugrides
Re: ifs crossmember
Thanks guys, makes sense to have it level at the rake you want. It did come with instructions nothing about leveling
