![]() Join Date: Apr 2011
Dip Stick for TH400 trans
Just got my TH400 back from the trans shop. It didn't have a dip stick when I purchased it from Bishops International. Got a universal one from the trans shop but, not happy with the way it mounts. It requires a two piece mount that is different from stock. I don't like it. Looking for one that will mount to bell housing like original. Found one at autozone from that is supposed to be like the original one. Here is a link to it
http://www.autozone.com/autozone/acc...er=309903_0_0_ Does anyone have experience with this. Would really like to find an original, GM factory stick if I could but, realize it may be hard to find. If anyone knows where I can find one or, if the one I gave the link to will work without wierd, two piece brackets to mount. Thanks for any help. |
#2 | |
![]() Join Date: Apr 2009
Re: Dip Stick for TH400 trans
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
Thanks for the reply 1971 GMC SHORTY, I'll go ahead and order one. I appreciate it!
One thing I just noticed is that, the one from autozone uses an o-ring. I've heard those are not the hot setup due to leaking. The universal one I have uses a press in rubber seal. Not sure if I'm going to order one of these or not.
Send me a PM about what you need.
You can still get those from a GM parts counter. Just tell them you have something like a 79 C10 with an M40 transmission.
I called 3 different places yesterday and, no one had one or, could get one. Thanks for the idea though.
![]() Join Date: Feb 2010
http://www.summitracing.com/parts/hup-hp2235
heres what i used, much better than those stupid dress up ones they sell. it has a push in seal...but is expensive |
#10 | |
