Old 08-28-2014, 09:35 PM   #1
davepl
davepl's Avatar
Power steering moan/whine
Before firing my truck for the first time, still using the original PS pump, I filled the reservoir. Once started it quickly sucked that it and I had no power steering.
I strongarmed it out of the garage and then topped it off. A little foamy in there, but not much.
Now it seems to have enough fluid but its groaning when you turn. Not quite the typical power steering whine, but similar.
Did I hoop the pump when it was low on fluid for a few 3-point turns?
Anything I can do? Magic mechanic in a can, or new pump?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-28-2014, 10:52 PM   #2
Fitz
Re: Power steering moan/whine
Air trapped in the steering gear can make it groan. Top off the reservoir, start it and cycle the steering lock to lock several times. If there was trapped air in the steering gear this will get rid of it. Shut it down and recheck the reservoir level. If it fell, top it off again & repeat. If it did not fall, get out your wallet because you will be buying stuff.
Fitz is offline   Reply With Quote
Old 08-28-2014, 11:30 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Without the engine running jack the front of the truck up and cycle the steering wheel lock to lock about 8 to 10 times. Check the fluid level. Fill if need be. Then start the engine and do the same thing... then check fluid again. This should help get any air out of the system and get rid of that groan.
If that don't fix it... then you will need a new pump.
Believe it or not... you can buy just the pump without the reservoir. Then you can install a new pump into your trucks reservoir. Saves you about 20 bucks at the parts store, and you keep your alignement on where the reservoir lines are.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-28-2014, 11:40 PM   #4
leddzepp
Moderator
leddzepp's Avatar
If you end up needing a new pump, you will not have any luck at a parts store. The big block units that had a remote reservoir are difficult to locate (at least they were when I was searching a few years ago). I think CPP now carries them, and maybe the Truck Shop.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-28-2014, 11:44 PM   #5
GASoline71
GASoline71's Avatar
Good catch mang... I didn't see that he has a 402.
Gary
