08-28-2014, 09:38 PM | #1 |
292 Chevy Had a Bad Day!!!
This was in my Ice Cream Truck. It was just running down the road about 45....um sure thats what my Nephew said anyway. Part of the cam was laying on the cross member.....Not for the faint at heart....
08-28-2014, 09:43 PM | #2 |
Re: 292 Chevy Had a Bad Day!!!
It'll polish out !
If you don't like this pound sand ..... |
08-28-2014, 09:45 PM | #3 |
A little JB Weld...No problemo.
08-28-2014, 09:56 PM | #4 |
in what first gear dang!
Between saying and doing many a pair of shoes are worn out |
08-28-2014, 10:13 PM | #5 |
Did you tell him that it needs oil even at 45MPH?
08-28-2014, 10:29 PM | #6 |
wow...she had a come apart alright! that sucks.
but the big question is ..... did the ice cream survive?
66 c10 Panel (Wife's) http://67-72chevytrucks.com/vboard/s...d.php?t=595684 68 c10 LWB |
08-29-2014, 05:18 AM | #7 |
It was full of oil and water. It was running perfect 10 minutes before. Now the truck has a GM Performance 325 h.p. crate motor. The truck is a P30 van and is way to big of a truck for a six Banger.....
08-29-2014, 05:40 AM | #8 |
Can you post some pics of the ice cream truck?
1961 Apache 10 with side trim 1964 4 door crew cab C20 1966 Chevy Suburban with custom trim 1961 K30 with a 4-53T Detroit diesel 1966 GMC 4X4 Suburban |
08-29-2014, 07:53 AM | #9 |
full of oil and water? hopefully not mixed!!! duct tape will cure that hole...
08-29-2014, 09:03 AM | #10 |
Ouch!
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
08-29-2014, 10:27 AM | #11 |
Ah....just put a little bondo on there....heck...it'll run fine the way it is!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
08-29-2014, 10:51 AM | #12 |
Wow, now that's some catostrophic failure!
08-29-2014, 11:23 AM | #13 |
Enjoy your truck
I know your pain (June 2005);
Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
08-29-2014, 11:35 AM | #14 |
08-29-2014, 11:45 AM | #15 |
Well I turn a 454 6,500 rpm's with a blower in a boat. It has four bolt mains,forged crank,forged pistons and dimple rods. I have run it about ten years without ever having a hick-up. That being said if it came apart id say I got my moneys worth out of it.
The 292 six is a different story. Last year I had one in the same truck. For whatever reason it got hot. It dropped about four exhaust seats. It also scored one cylinder like someone was grinding on it with a grinder. So my 292 days are over...between all these problems and the ex/intake manifold leaks I am not a fan of those motors. Only picture I could find of the truck. |
08-29-2014, 12:09 PM | #16 |
It's Better With Nitro
I can also relate…I once removed my camshaft out the top of my Pontiac block. 9K RPMs, valve spring failure, hung a valve, backfired through the supercharger.
08-29-2014, 12:11 PM | #17 |
Vin63 You WIN!!!!
08-29-2014, 12:33 PM | #18 |
Vin63--thats how Pontiac made their 4cyl lol!
1961 chevy K10 my build is------------61K10 build |
08-29-2014, 12:55 PM | #19 |
Six in a row makes it go...
Long stroke + higher rpm = high piston velocity (and corresponding high bearing loads).
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
08-29-2014, 01:34 PM | #20 |
Yep, although I think Mickey Thompson took a little more calculated approach to his.
When I raced my first 194 L6 in the early 1980s, I ended up with a couple of windows in the block just like Dan's 292. There were also some interesting bulges in the push rod covers on the other side.
08-29-2014, 02:25 PM | #21 |
No, I think this guy wins...he literally runs over the top half of the engine.
Never really heard anything bad about 292's, though. They screamed wide-open in all the trucks they came in and got a great reputation for reliability. No bad things to say about my own inline sixes, either.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread 1968 Impala 4 door sedan (future driver project) thread Last edited by 66Submarine; 08-29-2014 at 03:01 PM. |
08-29-2014, 05:21 PM | #22 | |
I really hate that for that 292...
1964 BBC 402 4x4 |
