Old 08-29-2014, 10:46 AM   #1
blazer2007
will tubular a-arms sit lower ?
My a-arms sit on the ground now but was wondering if I would sit abit lower with tube a-arms,pic would be nice .I see some like CPP are made a little thinner than some.
blazer2007 is offline   Reply With Quote
Old 08-29-2014, 10:50 AM   #2
blazer2007
Re: will tubular a-arms sit lower ?
yes is bagged
Old 08-29-2014, 12:50 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
No.
The a-arm pivot point is the lowest part of the front suspension.
Doesn't matter what brand you have.
Keith
Convert to disc brakes.
Old 08-30-2014, 04:54 AM   #4
andrewmp6
With out a dropmember or zing the frame its as low as it can go now.
andrewmp6 is offline   Reply With Quote
Old 08-30-2014, 07:14 AM   #5
IIGW
Are your arms shaved at the mount points? You can get about an inch lower by dragging them on the ground and shaving it all flat.
IIGW is offline   Reply With Quote
Old 08-30-2014, 09:05 AM   #6
blazer2007
so a tubalar a-arm would sit about 1 inch lower?
Old 09-01-2014, 12:52 AM   #7
IIGW
no.
Old 09-01-2014, 08:07 AM   #8
lolife99
lolife99's Avatar
This is as low as you can get with a stock crossmember and no frame Z.
A-arms won't change anything,...
Keith
Old 09-01-2014, 04:38 PM   #9
dec010974
dec010974's Avatar
Just for information purposes, (3) questions. In that pic lolife99, were the inner fenders removed? If I cupped the lower control, willing sit lower? What set up is that in the picture? I'll take that set up if it keeps me from spending $3300.00.
dec010974 is offline   Reply With Quote
Old 09-01-2014, 04:53 PM   #10
Bhelton
Bhelton's Avatar
Pancake the front member 1.5"
Bhelton is offline   Reply With Quote
Old 09-01-2014, 05:30 PM   #11
SCOTI
SCOTI's Avatar
Prob a random pic he has in his files.... Removal of the inner fenders, modifying them, or custom/aftermarket units will be required for any rolling stock combo < 27" or so (w/the x-member/a-arms touching the ground).
When using the bag spacers in the coil spring pocket or a plate (both used to prevent the bag from making contact @ the bottom portion of the a-arm) drop will be less vs cupping the lower arm.
Can't answer what that specifc set-up is but....
Cupped arms can get it lower vs not cupping.
A notched x-member can get it lower vs an un-modified x-member.
Dropped spindles help get it lower vs stock units.
Z-ing the frame can get it lower vs w/stock frame rails.
All these suggestions are less than the cost you mentioned but potentially not as safe either depending on the fab work & attention to safety related details.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-01-2014, 11:53 PM   #12
dec010974
dec010974's Avatar
Thanks for the info SCOTI. I guess in have my work cut out for me. My Air bags are installed using the bagged plates/brackets. I installed the belltech 3 inch drop spindles. I guess my next step will be to cup the lower control arms and remove my inner fenders and see how it sits. Thanks again SCOTI.
Old 09-02-2014, 12:18 AM   #13
SCOTI
SCOTI's Avatar
No prob. I'm carving up an extra set now. My goal is not max drop though.... I want the bags @ their spec'd height when I'm @ my desired ride height & it wasn't going to happen w/o slicing & dicing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-02-2014, 05:41 AM   #14
IIGW
And here is what I tried to explain earlier. The crossmember sits off the ground,
Some content in this post has been removed by the moderator as it advocates an unsafe practice.
Old 09-02-2014, 06:54 AM   #15
PGSigns
PGSigns's Avatar
That is a big time safety issue grinding the arms flat.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-02-2014, 07:29 AM   #16
lolife99
lolife99's Avatar
Originally Posted by IIGW View Post
And here is what I tried to explain earlier. The crossmember sits off the ground, Some content in this post has been removed by the moderator as it quotes material advocating an unsafe practice.
Really???
You can't be serious.
Keith
Old 09-18-2014, 09:11 PM   #17
ironadict
ironadict's Avatar
I have drop spindles, and cupped stock arms and my a arms sit hard. I've had a few accidental scrapes from riding low and the connection point of the a arm hitting the ground. Now my A arm is bent right there. I wouldn't recommend scraping them on purpose. Maybe with a grinder but even then I don't think it'll get ya much lower.
ironadict is offline   Reply With Quote
Old 09-18-2014, 10:04 PM   #18
dec010974
dec010974's Avatar
Thanks Ironadict. For the front bag install, I used the c10 bag plates. I'm not looking for maximum depth, I want the air bag to sit in the modified control arm evenly. Those plates suck. Every so often I have to adjust so that bags sit evenly for even air pressure. If one of that bags are positioned awkwardly on the spring pocket, it throws the bag pressures out of whack and the shor'Dee sits uneven.
