Old 08-29-2014, 11:51 AM   #1
Greghite
Washer pump
I bought a replacement pump for my 64 and it won't stop pumping... Any suggestions. Thank you
Greghite is offline   Reply With Quote
Old 08-29-2014, 03:36 PM   #2
1963c-10
1963c-10's Avatar
Re: Washer pump
Sounds like a defective unit. Did you have any issues with the switch prior to replacing the pump?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-30-2014, 05:57 PM   #3
T2vigil
T2vigil's Avatar
Re: Washer pump
I'm in the same boat. I ran out of time for more checking and have not gotten back to it. If there is a common answer I would be interested. I don't think it is a bad unit. Or I should say Hope.
T2vigil is offline   Reply With Quote
Old 08-30-2014, 08:37 PM   #4
Greghite
Re: Washer pump
Everything works fine 2 speed just keeps pumping fluid .. Switch isn't stuck operates freely
