Old 08-29-2014, 06:05 PM   #1
Orange72ChevyC10
Orange72ChevyC10's Avatar
Issues...
Ok I am trying to set my total timing and twice now I have fried a digital timing light. I went to check the voltage in the battery while running. See pic, is this normal?
It is 13.3 when not running.
Orange72ChevyC10 is offline   Reply With Quote
Old 08-29-2014, 06:07 PM   #2
Orange72ChevyC10
Re: Issues...
addt'l photo
Old 08-29-2014, 08:13 PM   #3
mater69
mater69's Avatar
Re: Issues...
This is just a thought....worth 2 cents maybe...but I think your alternator may be "overcharging" your system. Might want to check to make sure your voltage regulator is functioning properly(wired up correctly, turns on and off when the proper level of charge is present, etc.) If you are frying timing lights, you have too much power feeding them. I think the highest charge I have seen was around 14.5 when running...just a thought. I would definitely check the charging system though-you don't want an electrical fire!!
mater69 is offline   Reply With Quote
Old 08-30-2014, 06:57 AM   #4
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Re: Issues...
IIRC 14.6VDC is the maximum you want to see
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
Old 08-31-2014, 01:33 PM   #5
Orange72ChevyC10
Re: Issues...
Thanks for the info, I upgraded to an internal regulated alt. I'm reading 14.6 now. Let's see if I can NOT fry digital timing light #3....best $15 ext warranty ever.
Old 09-01-2014, 02:59 AM   #6
mater69
mater69's Avatar
Re: Issues...
yup, 14.5-14.6=good
15.4=bad...
